Go Back   PT Cruiser Forum > Regional Forums > Mountain PT Forum
2006 Trunk constantly releases
Old 21 Sep 2016, 04:34 pm
Default 2006 Trunk constantly releases
Hello, my name is Bill, have a 06 PT 4 door that most often the trunk releases when driving or standing still. Its loaded with all power and has a remote (2).
Once I lock the car when inside it seems to eliminate the problem.
Any help would be appreciated to help this mechanical challenged guy.
Old 12 Oct 2016, 05:59 am
rckstein's Avatar
Default Re: 2006 Trunk constantly releases
Welcome to the forum
I would suspect that the touchpad switch on the rear hatch assembly is failing, causing the lock actuator to trigger. You can search the forum for a repair on this, or you may need to replace the outside handle assembly if you want to stay stock.
'06 Touring Edition NA Automatic
151k Miles / Electric Blue Pearl
USMC '82 - '93
PCM or TCM? Constantly changing codes! TheFox Tech & Performance Forum 6 01 Jun 2016 02:34 pm
battery light on constantly nickred Tech & Performance Forum 5 13 Jan 2013 04:53 pm
MegaSquirt Releases a 41te ATX Controller UptownSport Tech & Performance Forum 0 27 Jan 2011 11:17 pm
Radio Constantly Skipping. Cathy06PT Sound and Security Forum 3 27 Mar 2009 11:59 pm
Trunk and trunk rack for the PT Cruiser jy_cruiser Exterior Accessories Forum 0 29 Oct 2001 10:32 am
