Go Back   PT Cruiser Forum > General Forums > Non-PT Discussions
Driveway Oil Spot
Old 01 Dec 2003, 02:17 pm
Default Driveway Oil Spot
My son's car developed a leak a couple months ago, and has since been fixed, but now I am left with an ugly oil spot on my cement driveway. The oil was synthetic, which seems to have added to the problem.
I have used 3 different driveway cleaners, and ACE oil spot driveway cleaner followed by my pressure washer. The spot is lighter now, but still remains.
What next?[:I]
Old 01 Dec 2003, 03:18 pm
Muriatic Acid. That's the standard concrete cleaner.
Also, there's kitty-litter-like oil absorbent that sucks most of it up.
Old 01 Dec 2003, 06:48 pm
Kirby,
I'm with you. Tried a bunch of stuff on the spots (mostly from people that visit) and I can get them lighter, but not fully removed. I did find out that "in time" they do almost fade away completely.[8D]
Old 01 Dec 2003, 07:27 pm
best chance is the Muriatic Acid
Old 01 Dec 2003, 09:32 pm
I have to agree with bobs pt & quicksilverdon. Thats the only way to go.
Old 02 Dec 2003, 03:59 pm
2sb 2sb is offline
If the other stuff doesn't get it as clean as you like, get a bag of dry oil absorbent. After you apply it, on a windless day, crush it on the concrete and let it set a few hours. At work when my stall was bad and one was available, I'd run a small asphalt roller over it! Cleaned much better than just pouring it on and sweeping it up.[]
Old 03 Dec 2003, 01:10 pm
I have the same problem.. Cement needs to be sealed contary to what people think. The pours can absorb all kinds of stuff. I have to clean mine well next spring. then seal. Keep in mind the two types of sealer. Membrane and penetrating. The penetrating is best, the material goes into the pours of the cement, creating a barrier not to allow contaminants from getting in. I made the mistake of using a membrane type (cheaper) and it didn't hold up. Now I have to make sure it is all off before I use the good stuff. Don't go to a hardware store either, find out where a construction supply company is near you. they will guide you toward what to use. Gary
Rust spot attributed to "Rail Dust"? Fireman The Detail Shop 4 06 Apr 2006 08:21 am
CTF4, registration spot #1, sold for $1,218.65 USD PT_Sean General PT Cruiser Discussions 0 11 Jun 2004 04:47 pm
Cruise the Falls 4, auction for reg. spot #1- $611 PT_Sean Canada PT Forum 3 07 Jun 2004 08:54 pm
water on the driveway? Gt_Cruiser General PT Cruiser Discussions 3 07 May 2004 11:25 pm
Cruise the Falls 3- Registration Spot #1, eBAY!!!! PT_Sean General PT Cruiser Discussions 2 02 Jul 2003 09:14 pm
