Go Back   PT Cruiser Forum > Regional Forums > Northeast PT Forum
Need a Mechanic
Old 01 Aug 2012, 11:09 pm
Default Need a Mechanic
Hi I have a 2005 pt le non turbo,and I have a cooling problem that I am at my wits end trying to fix.I am looking for a good pt mechanic in Sussex,New Jersey or close to Sussex.Even if you or they work out of a garage.Please post the information and I'll get back to you. Thanks
Old 02 Aug 2012, 01:15 am
Talking Re: Need a Mechanic
Have you told us what your problem is and what you have tried? Aren't there any Chrysler dealers in your area?
Old 02 Aug 2012, 06:55 am
Default Re: Need a Mechanic
/\/\ what he said /\/\
this forum has plenty of experience with cooling & over heating issues
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 02 Aug 2012, 09:41 am
Hi In response to earlier posts,yes there is a chrysler dealer near buy but I dont feel like getting ripped off,I don't trust dealerships.I'd rather give my money to a private mechanic.The problem I'm having is that everytime i run the car (enough time so that temp is at half way)and shut it down I hear bubbling gurggling noises from the over flow tank.The work I just did on it from like May this year is timing belt water pump job,new radiator cap,new thermostat,new cooling fan, bled the system numerous times,flushed radiator,had the test done with the blue fluid that turns yellow if the head gasket is shot (ok)All this when I ran the car the temp needle never went past half way mark,all that happens is when I shut it off I hear the bubbling noise.Now just yesterday I put a new temp sending switch in and now it just got worse,I drove it up some steep hills and the temp needle rose all the way to hot and I put the heater on full blast it came down a little but when I got home it was boiling and just spilled right out the tank.(cooling fan was running)So thats where I'm at now.Thats why I'm looking for somebody who is familar with this car.Any suggestions would be greatly appreciated.Thanks
Old 23 Sep 2012, 10:09 am
Interesting, I had this same problem. On mine it turned out to be the thermostat, but now my fan motor is not running.
Pittsburgh Mechanic spindy General Turbo Discussions 1 30 Nov 2011 11:51 am
Is my mechanic screwing me over? Beckysmalley Tech & Performance Forum 12 26 Jul 2011 02:24 pm
When AC is on PT overheats. Also looking for PT mechanic in NYC Marcos Northeast PT Forum 5 02 Jul 2011 06:29 pm
Is my mechanic asking too much? PtBrewzer General PT Cruiser Discussions 9 25 Jun 2011 02:01 pm
Off to the mechanic applepiemommy Wheels, Tires, Suspension 2 13 Apr 2011 12:30 pm
