Go Back   PT Cruiser Forum > Regional Forums > Northeast PT Forum
Help! Need advise please
  • 1 Post By ptcruisersteve
Old 18 May 2016, 12:52 pm
Question Help! Need advise please
Just acquired a 2005 vanilla pt cruiser 76000 miles great shape but it sat for over a year and the check engine lights has come on. Code says issue with brake switch. Replaced switch. Drove 50 miles to reset and light came back on with the same code. Now my horn doesn't work. And I have a fast blinking turn signal on the left which we thought indicated a dead bulb. Bulb was switched still have a fast blink. Please help. Any advise would be appreciated.
Old 18 May 2016, 03:25 pm
Default Re: Help! Need advise please
What was the code you got for the brake switch?
Old 18 May 2016, 07:43 pm
I am getting 3 codes now since the switch has been changed p0457 p0456 and p0572
Old 18 May 2016, 07:53 pm
P0572 was the original code.
Old 18 May 2016, 08:00 pm
LionPT's Avatar
P0456: EVAP
P0457: EVAP
P0572: Brake Switch 1 Stuck On
When the brake pedal is depressed, the stop light switch sends a signal to the Engine Control Module (ECM). When the ECM receives this signal, it cancels the cruise control.
All 3 codes could be from a bad vacuum hose. I suggest checking all the vacuum lines especially to & from the cruise control.
P0456/0457 could also be a bad gas cap.
Old 18 May 2016, 09:37 pm
P0572 = Brake Switch Circuit Low Conditions:
Possible Causes:
1. Intermittent condition Fused B+ circuit problem
2. Brake switch sense circuit is shorted to ground
3. Brake switch is closed
4. PCM has failed
Was the installation instructions followed when replacing the brake switch?
Old 19 May 2016, 12:34 pm
VsandFords's Avatar
My suggestion on checking to see if a blinker is not working is to turn on the hazard lights, walk around the vehicle and check all lights. I know a PT Cruiser is not like this, some vehicles have more than one bulb on each side that blink. There have been times when people would turn on the blinker , see one bulb blinking fast and not check the other side to see if there should be two or more that blink.
The old style mechanical flashers work off of a load/resistance. That's why you have to replace the flasher when you swap to LED lights. There is no resistance and it won't blink.
With saying all of this, I am making sure you are looking a the front and rear of the vehicle to be sure that all of the bulbs that should be blinking are.
Old 19 May 2016, 09:42 pm
Possible Causes:
4. PCM has failed
I am going to assume that the instructions were followed when replacing the switch because it was done by the mechanic but I can't say for certain.
Old 19 May 2016, 10:06 pm
Was it done recently? If so I would take it back and ask them to make sure the brake switch is operating properly.
ptprice likes this.
New guy in need of purchasing advise mayo General PT Cruiser Discussions 11 03 Jun 2013 08:11 am
Injector advise Kevhead Tech & Performance Forum 0 03 Feb 2012 10:41 pm
To keep or not to keep. Need advise. jazzbot General PT Cruiser Discussions 22 11 Nov 2011 12:20 am
Helpful help and advise bigbadwolph General PT Cruiser Discussions 4 13 Apr 2011 01:32 pm
Need some mechanical advise JShepherd General Turbo Discussions 11 19 Jul 2010 05:59 pm
