Go Back   PT Cruiser Forum > Regional Forums > Northwest PT Forum
No turn signals. Fuse Blows when Hazards turned off
Old 15 May 2014, 07:57 pm
Default No turn signals. Fuse Blows when Hazards turned off
I have been fighting this for almost all week, and am just not getting anywhere. I have an 04 PT, and awhile back I installed a tow hitch. With the tow hitch came an electronic interface supposedly designed to reduce the draw on the individual taillight circuits. I had it, so I installed it.
Last week, I had a situation where suddenly the dash lights went out, and next thing I know, no tail lights. After about a day and a half of searching I go to the tail lights to check connections, and find this thing burned beyond recognition. Well that explains what happened!!
I removed all traces of it, and put the tail lights back together. Still no tail lights. i did some more trouble shooting and managed to get the cluster lights working again.
I decided that the burning of the interface probably caused a wire to melt somewhere and short to ground, but I just can't find it. I even used a short tracer. It identified a spot where it thought the short was, and nothing!!!
What happens now is that with the hazard button depressed, I can replace the fuse and flasher and nothing happens. When I push the hazards button, the flasher buzzes for a second, and blows the fuse. Obviously a short somewhere, but where? I even went so far as to replace the MFS, with no satisfaction.
Hellllpppppp!
Old 15 May 2014, 08:16 pm
randyincctx's Avatar
Lightbulb Re: No turn signals. Fuse Blows when Hazards turned off
You should thoroughly check over the connectors & wiring to the MFS & fuse panel.
Pull the fuse panel,and look at the wiring from the backside....Look for any signs of 'burnt' wiring/insulation or connectors(signs of overheating).
Viewing the fuse block from the backside:
Back of fuse panel showing signs of burnt/melted wiring:
MFS with burnt/melted connector & wiring:
Aka:~KILLER~
INDICATORS TURN SIGNALS HAZARDS PATGAS Tech & Performance Forum 9 29 Oct 2013 04:59 pm
Fuse pops & wipers/ turn signals won't work... owensbigheart Tech & Performance Forum 1 11 Jun 2012 05:00 pm
Hazards and Turn signals out. KrisBo Tech & Performance Forum 4 29 Dec 2011 05:23 pm
2001 PT FP/ASD Fuse blows after 30 minutes angelsfanbp Tech & Performance Forum 1 25 Jul 2011 08:58 pm
Flasher Fuse #18 Blows Need Help F7daved Tech & Performance Forum 2 08 Mar 2010 05:53 pm
