If your sure the head gasket is ok, I'd say it's the fan...most likely the high speed. Read this post: New here....and a question & do the fan speed test.
![]() 2006 Touring Edition in Cool Vanilla...aka/Ghost |
1) It is NOT an interference engine-- not sure why you felt you had to rebuild the engine.
2) when timing belt was replaced, was water pump replaced? 3) have you had a head gasket test done? Depending on answers to 2&3, you may need a new radiator
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
A bad radiator cap or the wrong one can cause this. If not under pressure radiator will boil over at much lower temps
. 2004 Almond GT, autostick - Only car shows, some weekends but with Stage1! 2003 cranberry 5 speed GT - Fishing with a sleeper Stage3 setup! |
....and I never heard you say anything about burping the coolant system to make sure there's no air trapped inside. Needs to be done anytime that you have to add coolant.
Ok well It turns out my O ring for the water pump was bad along with bad radiator cap and bleeding the air out .... So the over heating stopped
![]() Now I have a new set of problems...... There is a loud grinding sound coming from my engine! I had a engine oil pressure sensor code pop up so I replaced that the oil light is still on . I also read that it could be the flex plat bolts loose would cause the sound so I checked that and they were loose so tighten them up took some of the sound away but it still sounds like its chewing some thing up???????? |
So, I bet that was expensive! To get at water pump is same labor as doing timing belt.
For Noise - open hood and try to locate what area noise is coming from. Did you have other belts replaced when timing belt was done?
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles Last edited by quicksilverdon; 21 Jul 2014 at 07:24 pm. |
The sound seems to be coming from the passenger side not sure if its the top or bottom..... I would post video but not sure how to do that on this site
As far as other belts no I believe I just changed the timing but put so many new parts on this car since feb so cant remember |
Are you not keeping good records?
my husband keep all records filed away as far as where he puts them I don't care normally to ask or go back and look never had this many problems on a car before my job is to just fix the car not keep track of records but I will have have to take a look
Thread Tools | |
Display Modes | |
FS - 2008 PT Cruiser LE - 48K miles - letting go of my baby | TsuKata | Classifieds: For Sale/Trade | 5 | 16 Dec 2013 10:09 am |
Help my baby( a 2001 pt cruiser) please | chefbunnyk | Tech & Performance Forum | 12 | 29 Jan 2013 09:01 am |
help my baby blue (pt cruiser)wont start!!!! | pttapp | Tech & Performance Forum | 2 | 12 Apr 2010 02:53 pm |
2003 Pt Cruiser Turbo - AC DONT WORKIE | ptshmoozer | General PT Cruiser Discussions | 4 | 15 Apr 2008 11:42 am |
PT Cruiser: Nobody's Baby | skylight | PT Cruiser News and Rumors | 1 | 15 May 2007 02:39 pm |
