What do you do, run red lights?
![]() You can't be making short hops with that mileage. Happy for you and WELCOME.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
what do you mean it is because of the returnless fuel system? and when the key is turned on and the starter not run the fuel pump will run and prime the lines and feed more fuel that is needed into the injector for a widened injector pulse width. It was bogging down from excess fuel by pressing the gas. Almost like a minor flood due to dual compensation for cold start.(increased fuel from both the ecu and the driver) Dan
<font color=\"blue\">Patriot Blue</font id=\"blue\"> 02 5-Spd |
It is a returnless system so whn fuel presssure is built to high, the pump is shut down. Instead of being routed through a fuel pressure regulator and sent back to the tank. Fuel pressure at the injector does not determine injector pulse width. That is controlled by the PCM. When you press the gas down it actually adjusts the timing by the PCM receiving a Throttle position signal so it does not bog down the engine. When you go WOT, it allows less fuel through the engine so it clears all the excess fuel that may be in the engine before dumping more. Kind of like a reset button. It's not like a carb that when you press the gas, it dumps a bunch of gas into the bowls and can dump down the intake and wash down the cylinders.
![]() \'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job \"Hondas are like cigarettes, everyone cool smokes them\" |
i know that pressure in an injector doesnt affect pulse width it is all the ecu but there needs to be pressure to have enough fuel in the lines to feed the widened pulse width and i know its not like a carb where u step on the gas and it dumps fuel but the ecu compensates for a cold start by widening pulse width and when you step on the gas that feeds more fuel as well in a mini flood like action the combustion chamber recieves a rush of fuel much more than cold engine and spark plugs would need. Thus the hard start.
When you turn the key one in a car the fuel pump turns on and builds Initial pressure to supply the injectors with fuel. So there is no reason that a hard start would be caused by a returnless fuel system. I still see no explanation for that thought. Dan
Welcome to the forum.
2006 PT Cruiser (NEW) 17X7 Motegi Wheels 215/45-17 Hankook Tire Front lowered 1.5 inches, rear lowered 2.5 inches Kenwood in dash CD/Sirius/Six Disk Changer First of a few mods ![]() 2004 Mercury Marauder (Supercharged) http://www.cardomain.com/id/bigslim2 http://www.cardomain.com/memberpage/484421 |
Sweeeeeetttt!!
ok but you are opening the throttle valve and letting more air in to mix with the fuel so it all balances out, right. Wrong.
The PCM runs a pre programmed starting cycle. Injector pulse width in our speed density calculated vehicles comes from three sensors. Intake air temp, crank position, and throttle position. The computer then adjusts pulse width in open loop mode. once special conditions are met the pcm monitors the 02 sensor and enters closed loop mode. So actually you are getting a lean condition of not enough fuel to start the vehicle when pressing the gas during starting. Example: If a vehicle with electronic fuel injection becomes flooded, depress the accelerator. The computer recognizes this as a clear flood condition, cuts off the injectors and the open throttle valve lets in maximum air to lean it out and allow the vehicle to start.
www.cardomain.com/id/rallydrock |
rally , this makes more sense to me now that i think about it, I would have to agree with you.
But still has no explanation as to why a returnless fuel system would affect it. Dan
thanks Dan, the brakes are awesome when you really honk 'em but are about the same as stock around town only squeakier. Have to clean the brake dust off once and a while.
With the return line that i needed with the turbo, the fuel pressure drops after the pump cycles on/off (ign. on). with returnless system i would say that the pressure would hold at about 55-60psi for a while because it has nowhere to go but back up into the line and the tank. PT fuel pressure is constant 58psi. Mine right now is anywhere from 60 all the way up to 120psi @ full boost. I will be bringing it down a bit with the installation of 26lb/hr injectors.
| I cant get an alignment with 20's goldline springs | ptcruz311 | Wheels, Tires, Suspension | 6 | 02 Aug 2006 05:28 pm |
| wheel alignment | onyx pt | Turbo Wheels/Suspension/Handling | 2 | 19 Aug 2005 09:10 pm |
| Roof Rack + Cargo Box | BB | General PT Cruiser Discussions | 3 | 28 Jan 2005 05:57 pm |
| camber alignment kit needed for front ??? | boosta | Turbo Wheels/Suspension/Handling | 7 | 10 Jun 2004 11:25 am |
| Roof Rack "factory installed" for GT | KevinM | Exterior Accessories Forum | 9 | 11 Apr 2004 12:25 pm |
