| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I haven't had any time to take it apart or do any more inspections, and I noticed during a recent warm spell we had, it mostly quit making the noise. As the leak appears to be in an area where glass slides against rubber, I probably can't add anything spongy to the area, as it wouldn't stay put. I will pull the mirror in time when the weather improves and see if there is anything out of place, or any holes that should be blanked behind the rubber that are not.
I finally got it into the dealer, and they say the rubber is damaged down inside somewhere. They ordered a new piece, will probably get it put on in the next few days.
Jack Smith Colorado PT Cruiser Club http://co.ptcruiserclub.org/colorado ![]() If You Haven\'t Cruised Colorado You Haven\'t Cruised |
The 06+ models have a big piece of foam in the forward door jam around the A-pillar area. I believe this is one of the things they did to quiet the Cruiser for the remodel. If you don't have that piece of foam, maybe you can buy it from a dealer, or buy a piece of foam like Cascade VB-5 and replicate the effect.
I have the same problem with my '05. I was told that I needed a new driver's side view mirror and had the entire thing replaced. Unfortunately, this hasn't helped.
I've been meaning to report back after the dealer did the work. The noise I have been experiencing is gone now. They replaced the piece that runs the length of the door, it is is called a door seal channel, front glass and is part # 5067279AD. I suspect this is the piece they replace when you have the frozen window TSB done, but haven't had a way to look that up either. The TSB # is 23-017-06, which I know puts an updated exterior rubber seal in.
This worked on mine:
Body - Wind Noise/Whistle From Side Window Area NUMBER: 23-021-05 GROUP: Body DATE: March 24, 2005 SUBJECT: Wind Noise At Side Window OVERVIEW: This bulletin involves relocating the foam stuffer at the end of the door outer belt seal. MODELS: 2005 (PT) Chrysler PT Cruiser SYMPTOM/CONDITION: A high pitch whistle sound from the mirror / door belt area may be heard at 30 mph - 50 mph (either left or right hand side). DIAGNOSIS: If the vehicle operator describes the symptom, perform the Repair Procedure. REPAIR PROCEDURE: 1. Lower the door glass, and remove the interior door mirror trim bezel (trim stick) for access to the mirror attach nuts. 2. Remove the (3) mirror attach nuts (8 mm wrench). Take care not to drop the nuts inside the door trim cavity. NOTE :The repair can be made without complete removal of the mirror which requires removal of the door trim for access to the wire connector. 3. You now have access to the outer belt foam "stuffer" located at the forward end of the belt seal, (Fig. 1). 4. Relocate the foam stuffer to stick out past the end of the belt seal by 2 mm - 4 mm (1/8 - 3/16 in.). 5. Install the door rearview mirror and attach with 3 nuts. 6. Install the door trim bezel. 7. Test drive the vehicle to verify the whistle sound is corrected. POLICY: Reimbursable within the provisions of the warranty.
Tim the ToolMan Little Rock, AR My babies are my dogs and my cars...4 of each 2005 PT Cruiser Convertible 2003 MBenz S500 1998 MBenz SL500 1997 MBenz E420 |
The description you listed for TSB 23-021-05 sounds a lot like what I was experiencing, but on mine, I know they replaced a bigger full length piece that required doing some real disassembly on the door itself. It's good to hear about the new TSB though, never know what will come out in the future.
| Wind noise at 90mph | turbomangt | General Turbo Discussions | 7 | 18 Mar 2005 12:27 am |
| Wind noise at 80mph | turbomangt | General Turbo Discussions | 7 | 16 Dec 2003 10:14 pm |
| Wind noise | ctmac | General PT Cruiser Discussions | 19 | 16 Dec 2003 03:58 am |
| Wind Noise | crzn8r | General PT Cruiser Discussions | 19 | 22 Nov 2003 04:17 am |
| question on wind noise from side windows | comPuTer | General PT Cruiser Discussions | 14 | 03 Sep 2003 09:12 am |
