PT Cruiser Forum Car Videos
Car Rims
Frozen Window Solution
Old 28 Feb 2008, 04:16 pm
SteveANJ SteveANJ is offline
Default Frozen Window Solution
Posted a thread a month ago concerning my windows not being able to do
the auto down once in awhile because they were wet and frozen in place.
The doors could be opened but when you closed them the window would gap
and flex.
It happened last Saturday night so I came up with a quick fix. Get in, pop the top a little, close the doors, put the top back down. By the time I got home running the heater they worked fine.
Old 04 Mar 2008, 02:30 pm
robert2183 robert2183 is offline
Default Re: Frozen Window Solution
and flex.
Last time my windows froze I just used a credit card along the bottom line of the window. Heard the thin ice shearing off as I moved the card along. Didn't do any noticeable damage to my card or anything that I noticed on the car.
~Robert
Old 05 Mar 2008, 10:02 pm
nomad327 nomad327 is offline
The credit card idea sounds like a winner if it works. I never had the problem until I dropped the car off at the dealer and it sat outdoors overnight in a storm. I noticed then, that the ice stuck on the window appeared to be only at the front 2" of the side window, and at the back 2".
Edit: I tried the credit card and it helped, but it seemed I had to saw it up and down some to get it to move front to back, which I would think would increase the possibility of hurting the rubber. I later tried a 1" putty knife blade, and it worked better. I held it in against the glass and was careful to avoid having the blade catch on the rubber. I was able to insert it at the door handle end between the glass and the rubber strip along the top of the door, and it slid back to front without much fuss. Also don't have to worry about dropping it down inside the door.
Old 14 Mar 2008, 06:18 pm
delrosen delrosen is offline
There are two options; first one is the credit card idea. This definitely works, I've used those supermarket club cards. Shove it in, a quick swipe along the entire window and the window will immediately drop.
The second option is a remote start. I bought a remote start and it's great. Letting the car run for about five minutes with the defrost on high not only gets the windows to drop but warms up the interior nicely.
vB code is On
Window Icing SteveANJ PT Cruiser Convertible Forum 8 03 Feb 2008 11:01 am
Window problems misfitwife PT Cruiser Convertible Forum 0 04 Jun 2005 12:50 pm
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
Weird hatch window replacement problem! SRG Tech & Performance Forum 6 20 Jan 2005 01:39 am
Window Problems in cold weather franski PT Cruiser Convertible Forum 0 26 Nov 2004 08:19 pm
  0 Credit Cards | Car Insurance | Secured Loans | Mortgages | Fast Loans
