chrome belt moulding...fittment?
Old 03 Aug 2008, 11:24 pm
teahead's Avatar
Thumbs down chrome belt moulding...fittment?
How do these suckers fit?
eBay Motors: PT Cruiser Chrome Convertible Curb Strips 5pc set (item 160267795813 end time Aug-11-08 13:06:23 PDT)
They look nice from the pics (anyone got any better pics w/them on?), but don't want to spend that kinda coin for crappy, uneven stick-on chrome.
2006 GT Convertible 5-speed Black
Eibach springs/ST sway bars
19x8.5 ADR wheels
235/35, 245/35 General UHPs
20% tint/XenonEyes HIDs
PTeazer Roll Pan
Borla dual 2.5" cat back
Old 04 Aug 2008, 12:55 pm
Default Re: chrome belt moulding...fittment?
i have these on my pt and and yes they do stick on and as they are stainless steel unless you are a moron you cannot stick them on uneven as for them looking crappy have you ever seen them in the flesh..i am always getting good remarks about them..if you still think they look crappy save your money for some chrome plastic stick on bits...
Old 04 Aug 2008, 03:44 pm
The car in the ad is mine. I can say the fit and durability are great. My car is a daily driver parked outside year round. On year three now with two winters under my belt, the finish has held up well and there have been no issues with any of the pieces loosening up.Here's a set of directions I made up for Maggie, follow these and you should have no issues.
Curb Strip installation:
Doors:
  1. Remove the inside mirror access panels (triangular shaped plastic).
  2. Disconnect wiring harness for power mirror (white plug).
  3. Remove the three 8mm nuts holding the mirror in place and remove mirror (deep socket or short extension may be helpful for lower nuts.)
  4. Test fit the door piece; they only go on one way so make sure the contour matches the existing door trim. Make sure the rear edge is approximately 1/16” from the end of the existing door trim as not to catch on anything getting in and out of the car.
  5. Clean down existing black trim, apply adhesion promoter and apply the door trim section working from the rear of the door forward.
  6. Reattach mirror, power plug and inside cover.
  7. Repeat process for the other door.
Rear Sections:
  1. Work one side at a time then attach the rear center section
  2. Test fit the pieces. Use the top inside edge of the existing trim as your guide.
  3. Clean down existing trim, apply adhesion promoter and apply the section working from the rear of the car forward.
  4. Repeat process for the other side.
  5. Test fit the center rear section. It should naturally match the existing trim. There will be gaps approx. ¼” between the center and side sections.
  6. Clean down existing trim, apply adhesion promoter and apply the center section.
Tips:
  1. Do not over tighten the mirrors.
  2. Use Prep-sol or 3M Adhesive and wax remover to clean the trim down.
  3. When applying the trim don’t completely remove the film from the 3M tape. Instead peel back enough to leave a tail so that you can pull off the tape film as you are sticking the piece down. This helps with positioning when first lying down the piece and ensures better contact since it allows for slight movement or corrections as the piece lies down. I’d recommend leaving tails at both ends just in case the film breaks while pulling it off from one side.
Old 04 Aug 2008, 04:29 pm
teahead's Avatar
THanks.
I have no problems them being stick-on.
I just didn't want trim that fit like junk. If they fit fine, then I'm sold as they do look nice.
Thanks a bunch!
19x8.5 ADR wheels
PTeazer Roll Pan
Your Mod List ucantcme General PT Cruiser Discussions 51 22 May 2009 10:54 am
Exterior Mod List slayerdarkcross Exterior Accessories Forum 8 22 Jul 2008 03:54 pm
Chrome "under the hood" stuff Franksredpt Classifieds: For Sale/Trade 5 22 Apr 2008 10:15 pm
2003 chromed out GT for sale bluebluegt Classifieds: For Sale/Trade 0 30 Jan 2005 09:37 pm
Check this out gonzomania Testing 5 10 May 2004 04:51 pm
