Tail lights blown out !!! ???
Old 15 Aug 2008, 08:28 am
Default Tail lights blown out !!! ???
Has anyone had an issue with their tail lights blowing out? I have replaced 3 tail lights in the last 2 weeks. They were completely broken, not just the filament, but also the glass!
Not sure what could cause this, and why it just started after 3 years with no problems. If you have had this problem, please let me know.
Old 15 Aug 2008, 08:52 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Default Re: Tail lights blown out !!! ???
have you checked the fuse to see if it's ok? also have you check the harness there for any fraying or cuts?
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 15 Aug 2008, 10:37 am
Are the same as the original, or have you changed to a higher wattage??
Old 17 Aug 2008, 02:25 pm
make sure that the bulbs are completely clean when you install them. oils from your fingers can heat up and do strange things to bulbs. clean the bulbs with denatured alcohol (or isopropyl) and dry with a clean cloth before install. latex gloves are nice, but you can use the rag to put the bulbs in. Do you have any moisture problems in the taillights?
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 18 Aug 2008, 12:34 pm
Thanks for the feedback. The fuse is OK, that was the first thing I checked. The new bulbs were all Mopar original. I'm wondering if there was some moisture ingression due to the folks at the car wash spraying the tail lights with their high-pressure hoses -- but this never happened before in 3.5 years of going to the same car wash.
Old 20 Aug 2008, 06:12 am
water getting in there ??
Old 25 Aug 2008, 03:04 pm
Cathy06PT's Avatar
Send a message via AIM to Cathy06PT
I used to have the same problem, not w/ my PT, But with my previous car (Cavalier) and it was always blowing out, I had to change the actual Scoket that the light bulb plugged into...it's a plastic piece that should pop off the wires. Once I did that, it stopped the problem....Other then that, is the seal good?
Old 29 Dec 2009, 06:37 pm
I have had 5 lights blown in 5 weeks - this seems to happen when I use the car wash that you drive thru - the lights are broken - not blown - have not found out how to correct
Old 29 Dec 2009, 08:33 pm
Well, you know the cause - water getting in.
Take out the lights, get some silicone caulking, and go to it! Seal any/all openings - go along the seam - and where the bulbs go in.
Old 20 Jun 2010, 04:51 pm
Smile Re: Tail lights blown out !!! ???
The solution for this problems is simple.
On heavy rain or car wash water infiltrate inside and condensate water/explode the bulb.
Take out both tail lights and glue a piece of FOAM on the Breathing Hole between the two lamp sockets.
Never close this hole otherwise you may melt your tail light with the lamp heat.
Cheers
PT 2006 from BRAZIL
Lucy390
PT Cruiser 1959 Cadillac tail lights available Marge Classifieds: For Sale/Trade 4 23 Oct 2009 02:31 pm
Tail Lights you've seen? PTmodrod Exterior Accessories Forum 2 13 Jan 2008 09:24 am
Jurassic Tail Lights 2step Exterior Accessories Forum 8 25 Jan 2005 07:03 pm
APC Gen 3 Chrome Tail Lights 4/SALE Lowered $ SwtNLwPT Classifieds: For Sale/Trade 0 07 Jan 2005 04:34 am
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
