Manual For Lincoln Navigator, Which Fuse Helps To Start The Car?
Old 21 Aug 2008, 06:24 pm
Default Manual For Lincoln Navigator, Which Fuse Helps To Start The Car?
Old 21 Aug 2008, 06:35 pm
Default Re: Manual For Lincoln Navigator, Which Fuse Helps To Start The Car?
This is a PT Cruiser forum.
Old 21 Aug 2008, 07:22 pm
I'm confused. Are you speaking English, and why was this posted in the PT Cruiser Convertible section of the forum? Probably the only thing in common between The Lincoln Navigator and the PT is they both roll on 4 tires.
Old 22 Aug 2008, 12:08 pm
LOL
Old 22 Aug 2008, 01:39 pm
Go here.
Ford Expedition Forum | Lincoln Navigator Forum - Ford Forums - Mustang Forum, Ford Trucks and Cars
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 22 Aug 2008, 02:18 pm
nevinsrt's Avatar
ROFL
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
"no fuse" light came on!!! hermtm2 General PT Cruiser Discussions 13 04 Jan 2012 07:56 am
Ignition Off Draw (IOD) Fuse Effects and Replacement Hints ObiMatt87 Tech & Performance Forum 15 24 Apr 2011 03:41 pm
Autometer gauges PTGT Redman Turbo Performance 12 23 Jul 2003 09:08 am
