Rear Window Noise
Old 27 Sep 2008, 05:44 pm
Default Rear Window Noise
Hi! I'm the new owner of an '05 GT convertible and so far I love it! It has 40k miles and had one owner.
My only complaint is the rear drivers side window. When the windows are up, it makes noise -- like it's rubbing against something. Sort of a squeaking sound.
I thought perhaps the rubber seal between the two windows needed lubricating or replacing, so I rolled just the rear window up so I could apply some lubricant. The window made noise by itself just be moving it back and forth by hand, so it's just the rear window and not the seal between the two.
Any ideas for correcting this? Thanks!
Old 27 Sep 2008, 09:34 pm
soonercruiser's Avatar
Cool Re: Rear Window Noise
See the post about 4 pages back in this thread.
wind noise at A pillar
Frank, aka SOONERCRUISER,
Old 28 Sep 2008, 11:39 am
Default Re: Rear Window Noise
Thanks, but the problem isn't wind noise.
Old 28 Sep 2008, 12:08 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
I know what you're talking about...one of my work vans does it.
I'll ask around and see what I can find out for the benefit of your PT and my work van.
Welcome to the forums!
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 04 Oct 2008, 09:00 am
welcome to the board !! is the car covered under any warranty ??
Old 29 Oct 2008, 08:04 pm
The rear 1/4 windows have a slight rattle. If you push out on them the nnoise stops. You can use a good quality silicone lube on the rubbers, solves about 10% of the problem the rest the window has to be "tipped out" at the top. The window has to be adjusted out wards. A good tech can do this in about 1/2 hour per window. We do it all the time.
Old 15 Jun 2009, 11:36 am
Howdy! I am the proud new owner of a 2005 base 'vert, and I've noticed the same rattle/squeek. I think in my case it is from the rear window being tipped too far forward. There is a black metal edge just to the rear of the rubber seal on the leading edge of the rear window. On the driver side the front window overlaps onto the metal, where on the passenger side the front window stays on the rubber seal (in front of the metal strip). Looks like the rear window needs to be rotated slightly backward.
Rear popping noise when braking kbrockman Tech & Performance Forum 9 29 Jul 2007 04:08 pm
Roaring noise from the rear when reversing?(FIXED) Ctown General PT Cruiser Discussions 3 17 Apr 2005 02:51 pm
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
Leaky rear window washer Jimbo General PT Cruiser Discussions 2 02 May 2004 09:33 am
Split Rear Window Kit sctvguy Exterior Accessories Forum 3 23 Oct 2003 01:01 pm
