window problem
  #11 (permalink)
Old 30 Aug 2009, 06:51 am
Default Re: window problem
I have a different window problem, most noticeable on my drivers side front window.
When raising the window all the way with switch, when it is fully up, it seems the motor is just "trying" to raise it a little more for a second, as if the glass is not seated properly but it is. I believe it even tries if I already released the up switch.
I have seen this now and then for the life of my car which is 2+ years and 8000 miles. Since no other problems developed I guess it's not serious; just something weird I cant understand.
  #12 (permalink)
Old 03 Apr 2010, 08:35 pm
whozwat's Avatar
I'll be darned. The suggestion to remove the negative cable for five minutes worked. Not only was power to the windows restored, but my non-operating convertible top came back to life. Who'd a thunk? Saved quite a few bucks, and since this is my daughters' car, made me a hero too. I had to register to this service just to thank whoever posted this suggestion.
  #13 (permalink)
Old 03 Apr 2010, 09:11 pm
Amazing what a little restart of the computer will do. It's like a problem at home. Reboot and everything goes back to normal. Worked a hundred different times for me.
  #14 (permalink)
Old 05 Apr 2010, 06:47 am
Thank's Turbozak. I had the same problem after jump starting the car.
I looked a long time for the fuse and found your thread:
A 10 minutes battery disconnection cured the problem
Originally Posted by turbozak View Post
Yes I had the same problem with all windows, the battery died, and I needed to jump start the car.
When I went to open the windows the windows where not working and the power top would not come down. The smart windows got a glitch, no you may not need to go to the dealer for them to reset it.
This is what I did with some experimenting.
1) First charge your battery in the car,
2) disconnect the battery lead to the battery
3) while waiting 5 minutes clean your terminals on battery
4) check your fluids, tire pressure and filter Just for the heck of it
5) reconnect terminals on your battery
6) get in car and gently close the door, the window as you know will be up to high, but this will trick your smart windows to think its in normal position with the door close
7) start your car and hopefully it as booted up to normal.
I did find the first time I did disconnect the battery for a few seconds , this did not work,
it did not clear the memory out of the system.
The other thing was the when I waited 5 minutes the radio station memory was not lost.
Don't rush it,
Good luck and please give me some feed back.
  #15 (permalink)
Old 08 Apr 2010, 11:13 am
Don't rush it,
Same problem with power windows and top quitting after winter storage and recharging a dead battery. The only thing I did different was I disconnected both battery cables and rubbed them together, this dischages the capacitors and resets the the window module , according to a electrician friend of mine . It worth try and doesn't cost anything, as a side note it also seemed to fix my rear view mirror compass and temp gauge .
  #16 (permalink)
Old 01 Jun 2011, 12:51 pm
I could have saved allot of time and gone to this forum first --- anyway IT WORKED!!! Thanks -- After the top and windows stopped operating on my 2005 PT Conver - I eventually followed the advise here disconnected the battery for 30 min hooked it back up and everything is fine --- I am sure the dealer would have done the same thing at no cost ---- right?????
After the winter - not driving - the battery died - and the top and windows stopped working --- thought I blew a fuse when I jumped the car -- nope --- all is good and it is nice to cruise again with the top down.... thanks for the 411
  #17 (permalink)
Old 03 Jun 2011, 12:24 pm
I would suggest that this thread be stickied, since it seems to happen a lot and the fix seems to work virtually 100% of the time...
2005 Dreamcruiser Conv. Deep Lava Red (not the plum color) with matching top. Infinity sound, two tone leather, High Output Turbo
2002 Durango 5.9 R/T. Cherry Red. Full time AWD, Infinity Sound, K&N intake.
  #18 (permalink)
Old 08 Jun 2011, 04:43 pm
I would like to thank y'all so much!!!!! The dealer was going to charge me $90 just to check the module in my door. I tried the battery trick and now my windows work again!!! Again thank you!!!!!
  #19 (permalink)
Old 05 Jul 2011, 09:32 pm
compdr59's Avatar
I have a 2005 Convertible. My drivers side front window will not go up. A few times last week it would only go up an inch or two at a time. I ordered a used replacement switch. In the meanwhile, I lubricated the regulator and the tracks. I hope that fixes it.
  #20 (permalink)
Old 08 Jul 2011, 09:52 pm
compdr59's Avatar
Good news. I ordered a used switch from justparts.com. I figured for $30, I would give it a shot. Plugged it in and everything works. Saved $100 from ordering from the dealer. Go to love it.
03 Cruiser PWR Window Problems. Help!! Slayer213 General PT Cruiser Discussions 7 10 Feb 2012 01:59 pm
Window problems misfitwife PT Cruiser Convertible Forum 7 15 Aug 2011 01:06 pm
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
Window Icing SteveANJ PT Cruiser Convertible Forum 8 03 Feb 2008 11:01 am
Weird hatch window replacement problem! SRG Tech & Performance Forum 6 20 Jan 2005 01:39 am
