Help! passenger front side noise; maybe wheel bearings?
Old 15 Jan 2010, 01:49 am
Default Help! passenger front side noise; maybe wheel bearings?
All,
Have a 2005 GT convertible with high output Turbo with 52,000 miles, and yesterday I heard a sort of grinding noise when I made a sharp right turn, but making a left turn is still quiet and no problem.
Would this be a wheel bearing problem, or something else? If so, where would be the best place to have this replaced? And should I have both sides replaced, or can I just have one done at a time?
Les Schaub, OEM, etc?
Thanks again!
Old 18 Jan 2010, 11:44 pm
soonercruiser's Avatar
Cool Re: Help! passenger front side noise; maybe wheel bearings?
What size tires?
Struts old?
Did the noise continue?
Are you sure it isn't the tire rubbing the wheel well?
Frank, aka SOONERCRUISER,
Old 22 Jan 2010, 02:44 pm
Default Re: Help! passenger front side noise; maybe wheel bearings?
I have 215 45R 17 tires. But I found out what was making the noise; it was a hub at the bottom of my steering column that was rubbing. Also one of my front strut bars was wearing out. Wasn't a wheel bearing at all, and the dealer said everything else looks fine. The dealer fixed both since I have an extended warranty, so nothing came out of my pocket and all is well.
Thanks for the replies!
Best front hub/wheel bearings to buy? Samson Wheels, Tires, Suspension 9 13 Aug 2010 11:45 am
KNOCKING ON FRONT PASSENGER SIDE SUSSPENSION PATGAS Wheels, Tires, Suspension 2 11 Oct 2009 12:48 am
little clicking noise from front right wheel yaris General PT Cruiser Discussions 4 31 May 2009 09:45 am
Changed Wheel Bearings New Noise 52smooth Wheels, Tires, Suspension 1 01 May 2008 05:58 am
2002 Cruiser Noise Front Wheel? johnjsa Wheels, Tires, Suspension 4 11 Dec 2007 03:08 pm
