Hi, and thanks for reading this ....
I have a 2005 PT Cruiser convertible. Sometimes, the top won't go up ... sometimes it does! and it's going up more slowly than it use to. help!?!!? thanks so much for suggestions! This is my first convertible and I absolutely LOVE this car! Marian |
Marian,
Welcome to the forum. Sometimes in order to help you, we need more information about your PT. Like the year, mileage. Question I have is how old is your battery. If the top is going up slower, the battery might be weak. I'm sure it takes a lot of amps to raise and lower the top. If you want to prove or disprove it's the battery, have someone with a good battery use jumper cables to yours and then try the top. If it works normal speed, then yours is getting weak.
ahh .... ok, it's a 2005 with 74,000 miles. I will try the battery strategy. I'm the second owner; I don't know how old the battery is, but I've had some slow starts sooo ... GEE, I would LOVE it to be a battery problem!!
thanks very much! Marian |
If you don't know the history of the PT, I would advise spending some money on it and getting and oil and filter change and new spark plugs and wires and maybe a transmission flush or a transaxle pan refill if money is tight. If you plan on keeping the car for a long time, it's best to start from scratch and this way you'll know the mileage when everything was done.
I have ran it on 2 out of state trips, including one to Washington DC (horrible traffic) and the wife drives it through city traffic every day. Runs smooth and I feel confident with her driving it and transporting our 4 year old son as well. Invest a little $$ up front on a used car and in the long run, it pays off... PS I "upgraded" the wipers and headlights as well......BIG difference!
2006 PT GT Vert - 2.4l Turbo, Black/Gray leather, MSD ignition wires, Royal Purple 5w-30 synth oil and filter, Sylvania Silverstar Headlight upgrade, TOYO Extensa High Performance tires ![]() ![]() ![]() ![]() ![]() Other rides: 2008 Honda Odyssey Touring Edition, NAV/DVD 2010 Toyota FJ Cruiser 4x4 Trail Teams Edition
This work for me.
here is the tsb SUBJECT: Power Windows (One Or Both Sides) And Possibly Power Convertible Top Inoperative OVERVIEW: This bulletin involves flash reprogramming the Smart Glass Module (SGM) or on some vehicles replacing the front window regulator/SGM assemblies. MODELS: 2005 (PT) Chrysler PT Cruiser Convertible NOTE: This bulletin applies to vehicles built prior to June 9, 2004 (MDH 0609XX) having Smart Glass Module software versions prior to Version 11.0 (as read with diagnostic tool). SYMPTOM/CONDITION: With the proper system voltage condition (10 -16 volts), the following conditions exist on either or both sides of the vehicle: No operation of the front and rear windows, including front window drop during door opening and window drop during convertible top operation. Unable to communicate with either or both SGMs with the DRBIII®. If the driver side SGM is affected, the driver side windows will exhibit the conditions described above as well as the power convertible top will be inoperative. DIAGNOSIS: After confirmation of the conditions identified above, the following reset procedure must be performed to determine the module hardware and software level: 1. Open both doors (provides a faster voltage decay in the SGMs). 2. **Disconnect and isolate the negative battery cable. 3. Keep the battery disconnected for a minimum of 15 minutes. 4. Reconnect the negative battery cable.** 5. Connect the DRBIII®, turn ignition switch to ON position and read hardware and software information for both of the SGMs. NUMBER: 08-035-05 GROUP: Electrical DATE: June 30, 2005 6. Dependent on the version of module hardware/software, follow the Repair Procedures to reprogram the SGM(s) or to replace the front window regulator/SGM assemblies. If the module software is Version 11.0, this service bulletin does not apply and further diagnosis is required. PARTS REQUIRED: Qty. Part No. Description AR (1) 05067452AE Regulator, Assembly w/ Smart Glass Module, Right Front Window AR (1) 05067453AE Regulator, Assembly w/ Smart Glass Module, Left Front Window SPECIAL TOOLS/EQUIPMENT REQUIRED: NPN Battery Charger CH2002 General Purpose Interface Bus Cable Assembly CH6000A Scan Tool (DRBIII®) CH7000A/7001A J1962 Cable with red DRBIII® connector TechCONNECT Workstation NOTE: An updated J1962 cable has been released. This cable has a red colored connector at the DRBIII® connection. Use this cable whenever a flash is being performed. REPAIR PROCEDURE: Module Resetting 1. Open both doors (provides a faster voltage decay in the SGMs) 2. **Disconnect and isolate the negative battery cable. 3. Keep the battery disconnected for a minimum of 15 minutes. 4. Reconnect the negative battery cable.** 5. Turn the ignition switch to the ON position, and try each of the four window switches to confirm operation. 6. If all windows move, then proceed to the Module Identification procedure. If the lock-up condition is still present on either side of the vehicle, or both, repeat steps 1 through 4, lengthening the time to 30 minutes. SGM Reprogramming NOTE: Whenever a module is reprogrammed, the software in the DRBIII®; must be programmed with the latest revision level available. NOTE: If this flash process is interrupted/aborted, the flash process should be restarted and then follow the directions on the DRBIII®. 08-035-05 -2- 1. Before beginning the flash procedure, remove any old flash files from the DRBIII® memory. To clear the memory from the MAIN MENU: a. Simultaneously press the “MORE” and “YES” keys. b. A screen will appear requesting a “COLD BOOT”. c. Follow the on screen instructions by selecting the “F4” key. d. When the DRBIII® reboots to the MAIN MENU, proceed to Step #2. NOTE: “Drivers Door” and “Passenger Door” in the DRBIII® display refers to the corresponding SGM's. 2. With the ignition switch in the “ON” position, determine the original part number of the SGM currently in the vehicle. Using the DRBIII® select: a. "DRBIII® Standalone" b. "1998 - 2005 Diagnostics" c. "All (Except Below)" d. “Body Interior” e. “Doors, Gate and Comfort” f. “Drivers Door” and/or “Passenger” g. “Module Display” h. Record the “SGM part #” on the repair order for later reference. 3. Connect the DRBIII® to TechCONNECT. Open TechTOOLS and verify that the "DRBIII® Status: Connected" message is in the upper right corner of the TechTOOLS screen. 4. Enter the “SGM part #” recorded in step 2h in the “Parts Criteria” area and select “Show Updates”. TechTOOLS will populate the appropriate flash file. 5. Select the flash file. 6. Select the “DRBIII” radio button which is next to the “Download/Update” button. 7. Select the “Download/Update” button. 8. Monitor the "Flash Download/Update Progress" window on the TechCONNECT and follow the instructions on TechCONNECT. When the flash download/update process is complete, proceed to step #9. 9. Disconnect the DRBIII® from TechCONNECT. 10. Open the hood, install a battery charger and verify that the charging rate provides approximately 13.5 volts. 11. Connect the DRBIII® to the vehicle. 12. Download the flash file from the DRBIII® to the vehicle. Using the DRBIII® select: a. “Vehicle Flash” b. Follow the directions on the DRBIII® screen. When the flash process is complete, perform the SGM Calibration procedure below. NOTE: Due to the SGM programming procedure, a DTC may be set in other modules (TCM, BCM, MIC, SKIM, etc.) within the vehicle, if so equipped. Some DTC's may cause the MIL to illuminate. Check all modules using “Module Scan”, record the DTC's, and erase these DTC's prior to returning the vehicle to the customer. Erase any DTC's in the PCM only after all other modules have had their DTC's erased. 13. Turn the ignition switch to the ON position. 14. Confirm all window and power top functions. 15. Confirm no occurrence of new DTCs. NOTE: If the SGM(s) would not accept the flash update, replace the window regulator/SGM assembly(s). -3- 08-035-05 Window Regulator/SGM Replacement 1. Replace both front window regulator/SMG assemblies following procedures outlined on TechCONNECT. 2. Following the installation of the new regulator/SGM assemblies, perform the Smart Glass Calibration procedure below. 3. Clear any SGM DTCs with the DRBIII®. 4. Turn the ignition switch to the ON position. 5. Confirm all window and power top functions. 6. Confirm no occurrence of new DTCs. SGM Calibration After the replacing the regulator assemblies or reprogramming the SGMs, the modules must be calibrated to "learn" the full up position. The calibration procedure must be individually performed on the driver side and passenger side SGMs. 1. Turn the ignition switch to the ON position. 2. Hold the front window switch for the appropriate side in the UP position and stall the window closed for 5 seconds. Release the switch. 3. Open the door by pulling internal door handle and hold the door handle in the open position for 5 seconds. Release the handle. 4. Hold the same front window switch in the UP position to stall the window closed for 5 seconds. Release the switch. 5. Confirm that the window drops when the door is opened and returns to the full up position when the door is closed. 6. Repeat steps 1-5 for the other side as necessary. 7. Set the clock to the correct time. POLICY: Reimbursable within the provisions of the warranty. just try openingthe doors unhook the battery for like 15-20 min then hook up the battery and try them. or if under waranty take it in. _________________
Steve / Wayne, NJ 2005 GT Convertible Black on Black, Stage 1, Blk Battery Cover, Mopar Stage 2 coilover kit, BTG Strut Bar, Eibach front and rear Anti-Sway Bar Kit, BOV valve,Magnecor wires, Mopar Dual Exhaust, 235/40/18 Sumitomo HTR Z II tires w/ Konieg Sideways Wheels Chrome Fuel Door Cover and Side Door Spears Covers, Tinted Windows, Blk/Red Coco Mats, |
| Tags |
| convertible, electrical problems |
