2005 convertible problem
Old 18 Mar 2011, 12:44 am
Default 2005 convertible problem
Are there any adjustments for the convertible top? When I put the top down it doesn't seem to go all the way down. It looks as if one of the roof bars isn't positioning correctly ?
Old 18 Mar 2011, 06:13 am
Default Re: 2005 convertible problem
See if this helps:
Top does not go all the way down
Old 18 Mar 2011, 08:04 am
I don't know if there are adjustments, but I do know that I've had problems with my roof lowering properly. With it about 70% open, you need to look in and around where the top stores and make sure there is nothing there blocking it.
Also, the roof tends to touch against the back trim piece that sits over the top of the trunk. There is a piece with four screws that, on my PT, got hooked to the top somehow and when closing the top I ripped that trim piece right off. $158 from the dealership so I'm riding without it, which is a minor risk.
Anyway, here's a list of things to look at when troubleshooting this issue:
  • When opening the top, look at each fold point of the metal frame to insure there is nothing there that would be keeping the frame from folding in on itself properly.
  • With top about 70% open, go to the back area and look around the rear window and storage place where the top folds up, make sure there is nothing in there.
  • Take some cheap white chalk and rub it on the trim piece over the trunk, along with the four screws that hold it in. Lower the top as far as it will go, then raise the top again. See if you have chalk on your top showing where it may be hitting.
  • Verify that your rear windows are all the way down before lowering the top, it could be the auto-circuit controlling the window lowering that is bad.
Now I just looked in the service manual and there is an entire section dedicated to diagnosing problems with the top in the verts. If you have a service manual you might want to check that out, it's got too much info in it for me to go into details here. If you don't have a service manual, PM me as I have them in PDF format.
I'd go out and check other items on my top as hints but my poor baby is still in the shop from my wreck.
Old 07 Nov 2013, 02:13 pm
Default Re: 2007 convertible problem
Hi I just got a 2007 PT Cruiser and the to dose hit the back molding. If you could send me the PDF File to scott@ecrcpc.com it would be appreciated thank you
Old 12 Nov 2013, 09:35 am
I would be interested in the service info pertaining to the convertible if you are sending it out
Old 01 Dec 2013, 12:11 pm
Guys, no offense but please remove your email addy's from the posts - they are publicly displayed and they can be taken and used and that's not good. I emailed you both info and it's okay if you PM someone, but I don't suggest posting your email address publicly, just puts it at risk.
Originally Posted by nomad327 View Post
I would be interested in the service info pertaining to the convertible if you are sending it out.
Thanks in advance.
Originally Posted by Sweglas View Post
Hi I just got a 2007 PT Cruiser and the to dose hit the back molding. If you could send me the PDF File to it would be appreciated thank you
Anyone else interested, PM me!
Old 21 Dec 2013, 11:26 pm
Send a message via AIM to manakorin Send a message via Skype™ to manakorin
Seems like a mechanical problem. Did you manage to fix it yet?
atlantarhinoplastycritic
FS 2005 GT Convertible fljohnboy Classifieds: For Sale/Trade 10 13 Jun 2013 10:07 pm
2005 GT Convertible Brakes ??? logonsys PT Cruiser Convertible Forum 17 10 May 2011 04:53 pm
2005 2005 Convertible top/drivers windows not working rabidaardvark PT Cruiser Convertible Forum 6 08 Sep 2010 10:48 pm
2005 convertible Halo Tech & Performance Forum 0 26 Aug 2010 07:51 pm
Hitch for 2005 Convertible westgate Exterior Accessories Forum 4 24 Mar 2004 09:08 am
