head gasket replacement and cam/crank relearn
Old 18 May 2011, 09:02 am
Default head gasket replacement and cam/crank relearn
so im going to have to do a head job on the 2001 pt cruiser n/a.
i was reading over the procedure, and it states that after the work is done that you have to do ,cam/crank postion relearn with a "DRB" scan tool, to have the timing right.
so the questions are:
1) is the use of "drb"tool and the "relearn" mandatory?
2) if the head is bad/ cracked or overly warped. i was reading about a head design change after the 2001 model is this just a bolt on affair?
3) if not. can you still find good 2001 designed heads?
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Head gasket ? scorpiostu Tech & Performance Forum 3 28 Mar 2011 04:33 pm
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
head gasket broadleaspeaking1 General PT Cruiser Discussions 1 27 Mar 2008 05:44 am
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
