Corroded battery cable
Old 25 Jul 2011, 06:56 am
QuarterFlash's Avatar
Default Corroded battery cable
I am having the worst time with my negative battery terminal. I mean I know Dodge/Chryslers tend to have a lot of build up, but Quarterflash is reaching ridiculous levels. Literally every 2 months or so the green powdery gunk has gotten so bad that you can't really see the terminal any more and it has to be thoroughly cleaned.
This past weekend the clamp finally snapped off at the neck and I had to replace it (in 102 degree heat, no less).
Anybody have a good, effective way of at least slowing it down to maybe once a year? I've tried the felt pads but they don't really seem to do much good. I've seen some guys slather grease all over the terminals. Any other ideas?
2005 Dreamcruiser Series 4 Convertible. Deep Lava Red (not the plum color) with matching top. Infinity sound, two tone leather, High Output Turbo
2002 Durango 5.9 R/T. Cherry Red. Full time AWD, Infinity Sound, K&N intake.
Old 25 Jul 2011, 08:43 am
VNT's Avatar
VNT VNT is offline
Default Re: Corroded battery cable
I use the washers and then spray the terminal with some Red film battery terminal spray.
You can buy a pair of terminal washers and the spray for about 4$ .
I never have issues with corroded terminals.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 25 Jul 2011, 03:16 pm
Yea, any decent auto store will sell a variety of different things to help reduce corrosion build up.
Old 25 Jul 2011, 05:15 pm
chigger_ns's Avatar
I use marine grade brass clamps with dielectric grease.
Seems to work great
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 25 Jul 2011, 10:50 pm
soonercruiser's Avatar
Cool Re: Corroded battery cable
Of the 3 Cruisers I have owned, only one had that problem. And it was the thin double ring design clamp. I had a heck of a time keeping it clean.....neglected it once!
ZAP!
SHORTED OFF!
Lucky my 5-Star dealer was able on braze on a heavier terminal clamp.
No problem after that.
If you have that thin, double ring design clamp, you may want to change it out.
Frank, aka SOONERCRUISER,
Old 26 Jul 2011, 11:25 am
Thanks all. Since I've already tried the washers, look like the red spray grease is my next thing to try. Or maybe both...
Old 26 Jul 2011, 12:41 pm
I use a thin coat of bearing grease after a thourough cleaning--seems to work
Old 26 Jul 2011, 08:24 pm
BTW - be careful cleaning off the corrosion.
This is an acid salt. Simple brushing can flick some flecks of the acid salt in you eyes, or simply on your skin......wher the moisture will reconstitute acid.
What I have done is mix a little baking soda in a plastic bowl with with tap water, a pour it over the area of corrosion. (foams up and dissolves the salts) Then rinse well with plain water.
Battery Cable Assy - did I get taken? ZoomZoom71 Tech & Performance Forum 6 23 Jun 2010 08:18 pm
Battery cable upgrade Carl48 General PT Cruiser Discussions 3 16 May 2010 01:01 pm
Battery Cable Confusion captainkrm Tech & Performance Forum 6 05 Mar 2010 10:55 pm
Battery Cable Assembly... PTGirl2001 Tech & Performance Forum 0 19 Nov 2009 01:00 am
Disconnecting battery cable TaylorMade Tech & Performance Forum 6 08 Aug 2004 11:24 am
