06 PT Vert Radiator
Old 24 Apr 2012, 08:27 pm
TakenItEasy's Avatar
Default 06 PT Vert Radiator
I went to change my coolent yesterday and when I tried to drain the Radiator, The drain valve wouldn't allow any coolent out. The valve would only turn 180% and then stop. I tried pulling on it, But since it's made of plastic, I didn't pull on it too hard as I didn't want to break it.
I pulled the lower radiator hose and drained it that way. Can someone enlighten me as to the proper way to get the &^**# drain valve to work?
J
"There is no Glue strong enough to mend a broken promise."
Old 24 Apr 2012, 09:05 pm
Default Re: 06 PT Vert Radiator
You didn't curse the poor plastic drain valve did you? if you would read your owners manual ...you do have an owners manual don't you? It says to only turn it 1/4 to 1/2 turn. It doesn't screw all the way out, not supposed to. Also take off the radiator cap to help it drain.
Another little tid-bit, if it's been years since you drained it last, you probably have enough junk and debris on the bottom of the radiator where, taking the lower radiator hose off would be the only way to empty it. Then it needs to be taken to a shop and power washed to clean out the inside and outsides of the whole radiator.
Old 10 May 2012, 10:57 pm
Guys, I've seen postings time and again about the radiator fans and guesses as to diagnosing the problems, overheating engines, etc. In the OEM Service Manual there is an entire section dedicated to the engine cooling system and how to troubleshoot it. I was going to post this in my library thread but it's locked, so I'll post it individually until Crewzin unlocks it.
Now, the service manuals are different for '06 and up, however if I were you and I was troubleshooting overheating problems, I'd download both because they both have excellent info in them.
Here they are, you can download directly from my web library:
2000-2005 PT Engine Cooling System
& 2006 and up PT Engine Cooling System.
Looking at an 05 GT 'vert. RaineMan PT Cruiser Convertible Forum 17 13 Jun 2011 07:07 am
'06 Vert Photoshoot Chromenut PT Cruiser Convertible Forum 12 22 Apr 2011 06:02 am
GT vert Turbo careyk General PT Cruiser Discussions 8 21 Apr 2008 11:51 pm
New PT vert pics...... TexasCruiser PT Cruiser Convertible Forum 1 09 Jul 2007 07:46 pm
05 Vert pics..... TexasCruiser General PT Cruiser Discussions 1 09 Jul 2007 03:35 pm
