Engine Mounts
Old 05 Sep 2012, 06:19 pm
Default Engine Mounts
I just bought a 2005 Pt Cruiser Convertible Touring Edition with 2.4L Turbo. It has 90,000 miles. It is time for a little maintenace. I am replacing the worn out engine mounts. I have already replaced the easy to get to right side upper and lower strut mounts. I have also replaced the left side transmission mount. The difficult one to get to on the right side between the timing belt and the right frame looks like a pain. QUESTION: is it worth replacing since I have already done 3 of the 4 mounts. Or would I be dumb to leave it as a weak point causing my 3 new mounts to wear early because of my laziness
Old 05 Sep 2012, 06:55 pm
Default Re: Engine Mounts
It's not that hard. Go to the Tech & Performance part of the forum and look for the HOW TO thread. Inside that thread are about 2 dozen or more helpful threads on doing almost everything on the PT. Look for the HOW TO on the lower motor mount.
Old 06 Sep 2012, 10:37 am
it's a PITB. leave it alone or do it when you change the timing belt. that mount usually never fails. the top and bottom tear frequently.
if you're at 90k you'll be doing the timing belt soon(whether you want to or not). that is probably why they sold the car in the first place. it will break at 100k. since you'll have it all apart anyways, you can check the mount then, although it's probably fine.
Vibration after new engine mounts Capriman86 Tech & Performance Forum 22 05 Apr 2013 01:27 pm
engine mounts lt4supr Turbo Performance 25 05 Oct 2011 01:19 pm
Engine top cover mounts? Teknoron67 General PT Cruiser Discussions 7 17 Jul 2011 11:23 pm
engine mounts lt4supr General PT Cruiser Discussions 11 04 Jun 2008 07:56 am
Engine mounts KingKole02 Tech & Performance Forum 3 13 Jan 2005 04:04 pm
