I have a 2006 PT conv with 33K miles and it has had a miss at idle for a while, with Check engine light on. A diagnostic check at the dealer showed valve misfire at #4. They changed the spark plug, no change, changed the spark plug wire, no change. Now they want to take the head off to check for a what they suspect is a burnt valve. Is it just me, or is this a bit ridiculous for an engine with this low a mileage? By the way, the car has been regularly maintained by this shop ever since it was new.
THANKS Mike Last edited by mwomack; 13 Sep 2012 at 03:59 pm. |
Anything can happen , no matter what mileage you have but there are other less expensive ways to check.
What are the symptoms of a burnt valve or blown head? - Yahoo! Answers Burned Exhaust Valve Symptoms | eHow.com What are the symptoms of a burnt valve and how can I verify it? - Yahoo! Answers What are symptoms of a burnt valve? - Yahoo! Answers Burnt valve - U tube |
There are reports of burnt valves periodically in the '01 & up NA 2.4, and seen one my self on a sedan:
![]() Old 2.4's had a slightly larger exhaust valve, and didn't burn valves, no matter the maintenance or lack thereof. I suspect Chrysler tried to save some $ and went just a bit too far- the new valve looks light (thin) to me, but as if I'm a valve thickness expert ...
Useful Documents Useful How-To's Have an engine code? Sometimes this link is helpful Neon Bobble Strut ^^ Click |
Funny you brought this up, i just talked with a guy at a local Car Show with a 06 PT GT that was telling me about a problem that he had with his. Took it to the dealer they told him he had a burnt valve charged him $1000 dollars he was there when they started it after they put it back together had the same miss. After they checked it again they found a wire somewhere in engine harness that had rubbed a bare spot said they put shrink wrap and black tape on it fixed the miss but still cost him the $1000.00 ... just something to look for ..
![]() Quote:
Go to a local parts store that has been around for a long time. Ask them to give you a list of the local mechanics that they would take their car to. Ask your NEW mechanic to; 1. Check for intake gasket leaks. If this is it, you don't need steps 2 and 3 2. Run a vacuum gauge check on all the cylinders 3. Do leak down test. None of the above fall into the realm of rocket science and should be the normal first steps in diagnosing a misfire by any even half/competent shop (mechanic). It's automobile mechanics 101. Please click below. Jerry Last edited by wwpptc; 13 Sep 2012 at 09:53 pm. |
![]() Quote:
![]() Quote:
NP-
easiest way is a compression check- It'd be about ZERO WW is right on- Those old timers reach for a vacuum gauge before a scan tool! GT, I would guess, shouldn't have this problem- Eventhough everythings EXACTLY the same- they use a higher quality valve on turbo engines.
From what the guy was telling me about his it wasn`t a bad spark plug wire it was actually a rubbed spot in an electrical wire somewhere under the hood not sure where but he said this fixed his. Good luck with yours and keep us posted.
That's just pure craziness. I had a reputable dealer tell me that my #6 exhaust valve was shot and that I should "junk my car" (which is a 1996 Intrepid with 80,000 miles). I didn't trust his opinion because I had just taken old sparks plugs out of it and #6 plug looked great. And they were very old plugs. So then I compression tested it. It tested perfectly. I eventually replaced the ignition coil pack and the car has been perfect ever since. I had the same problem as you and the dealer told me the same thing. They wanted $1200 to do the job, but advised me to "junk the car". It literally runs perfect now. Please dont listen to these A-holes (the shady salesmen dealer garage people)!
We also have a 2003 PT. I just had the same exact diagnosis on my Intrepid from a "reputable" Chrysler mechanic |
Tags |
burnt valve, header, low mileage |
Thread Tools | |
Display Modes | |
badly need help, burnt valve ? | greasemonkeyjmj | Tech & Performance Forum | 37 | 13 Mar 2012 09:55 pm |
WTB CD Repair Disc for 2006 GT Conv | TakenItEasy | Classifieds: Want To Buy | 0 | 23 Jun 2009 11:06 pm |
2006 PT Limited Ed Mileage is terrible. | vetteloverpa | General PT Cruiser Discussions | 45 | 11 Mar 2008 12:09 am |
2006 PT Cruiser Conv. GT | matt87951 | General PT Cruiser Discussions | 10 | 28 Sep 2007 03:56 pm |
Base Conv. VS Touring Conv. | matt87951 | PT Cruiser Convertible Forum | 13 | 22 May 2007 12:22 am |
