Camshaft and crankshaft
Old 06 Oct 2012, 12:37 pm
Default Camshaft and crankshaft
I have 2005 PT Cruiser Conv Touring Edition with turbo.
I have a check engine light that says to replace CMP sensor.
Where is Camshaft Position sensor located?
Does target magent behind CMP sensor also need to be replaced at same time?
Also will do crankshaft, Where is crankshaft position sensor located?
Old 06 Oct 2012, 12:58 pm
Default Re: Camshaft and crankshaft
Cam sensor is on driver side on the end of head. It's black and round with two 8 mm bolts and a connector. Magnet usually OK. About a ten minute job. The other one is under the starter in the front a lot more work. Not sure the best approach. They don't fail near as much as the other one. Most people here prefer OEM rather than aftermarket. Just throw the cam sensor in and see if you have any more problems.
Old 06 Oct 2012, 02:51 pm
Camshaft sensor and magnet
Crankshaft sensor
Crankshaft sensor
Old 06 Oct 2012, 04:02 pm
thanks
I replaced the camshaft sensor, easy after I found it. I did NOT replace crankshaft sensor, too much of a pain to get to and check engine code was specifically for camshaft.
Car runs MUCH smoother now at idle and at acceleration. check engine light did go out, so all is good.
One note, I seam to have lost some horsepower. Is that possible?
I did use after market part from Autozone.
Old 06 Oct 2012, 04:40 pm
Aftermarket sensors don't seem to last very long. Proven fact from those who used them. Wouldn't think you would lose anything from them. Keep an eye out for the same symptoms you had before, then try a genuine MOPAR sensor.
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
Camshaft seals and crankshaft seal? Krueger86 Tech & Performance Forum 2 20 Apr 2011 11:32 am
Camshaft & crankshaft sensors southerncruiser Tech & Performance Forum 2 17 Mar 2011 08:45 am
Crankshaft BACdaG1 Feedback and Support 0 09 Nov 2010 09:36 pm
Camshaft/Crankshaft Synchronization Procedure DigitaL101 Tech & Performance Forum 1 12 Apr 2010 01:21 am
