whistling window
Old 08 Jun 2013, 03:55 pm
Default whistling window
2005 GT HO turbo, and my passenger side window whistles...very annoying...does yours?
Old 08 Jun 2013, 04:00 pm
Default Re: whistling window
If the door seal are in good shape then you need to do a glass adjustment. If you have to ask about this DON"T attempt to do it yourself it is easy to make it worse then it is. Many auto glass shop can do it for a flat rate charge of 1 hour.
Old 08 Jun 2013, 05:07 pm
Originally Posted by NitroPT View Post
... a glass adjustment. If you have to ask about this DON"T attempt to do it yourself it is easy to make it worse then it is. ....
OK, that sounds like a challenge. My windows are a bit looser than I'd like, and I had figured it was a (for me) DIY project.
Old 09 Jun 2013, 09:37 am
I will be watching your results....hahahaha!
Seriously...read a factory service manual before you start and do small adjustments and check. Good Luck!
Whistling sound on my 04 SE Quickmr2 General PT Cruiser Discussions 0 16 Apr 2013 11:23 pm
whistling sound nicksbar General PT Cruiser Discussions 4 04 Feb 2012 09:52 pm
whirring whistling noise fancy Tech & Performance Forum 1 29 Oct 2011 05:58 pm
whistling noise fancy Tech & Performance Forum 1 11 Oct 2011 06:43 am
Steering is whistling...?! whitbyPT Wheels, Tires, Suspension 2 27 Jul 2008 01:42 pm
