Top Does Not Go all The Way Down
Old 11 Aug 2013, 12:41 am
Default Top Does Not Go all The Way Down
I just purchased a 2006 PT convertible that has a boot with it. It seems that the top does not go down all the way as the boot cover does not fit. It seems like the second rail from the front is hitting the rear trim on both sides by about 1/2 inch as it closes. In other words, the two rails in the front are both above the trim line. In pictures online it seems that only the first rail (the header with the handle) is above the trim line. Any suggestions?
We just figured it out! You have to hold the material out as the top is opening so that it does not get caught between the rails.
Last edited by Dreamer853; 11 Aug 2013 at 03:09 pm. Reason: Figured out the issue.
Old 11 Aug 2013, 05:58 pm
Default Re: Top Does Not Go all The Way Down
You should not have to hold anything but the top down button when putting your top down. Something isn't working correctly when yours is going down. You may want to have a dealer look at it.
