Dodge Neon rims
Like Tree3Likes
Old 29 Aug 2013, 06:07 am
Default Dodge Neon rims
Will OEM 15" 03-05 Dodge Neon aluminium rims bolt up on a 2005 PT Cruiser? I found a set for cheap and want to get them if they will bolt right up with no issues. Thanks in advance for any help.
Old 29 Aug 2013, 10:01 am
Default Re: Dodge Neon rims
Only way I know to be certain is to try them - aside from bolt pattern and offset, there's clearing brake calipers..
I am quite sure they would - if yours is not a turbo - I know the Neon SRT-4 wheels fit all PTs.
kda66 likes this.
Old 29 Aug 2013, 10:45 am
Ray_Dockrey's Avatar
Being a turbo won't matter. There have been a few here that have run regular 15" steel wheels on their GT's with no issues. I am sure they will fit.
Busted_PT and kda66 like this.
Old 29 Aug 2013, 02:24 pm
Thanks for the replies! I was thinking that they would but wanted to make sure.
Old 29 Aug 2013, 09:56 pm
InfernoGT's Avatar
Just need taller tires. The cruisers have about 1" larger diameter tires than neons. These are 235/45 R17 tires on my cruiser. These are 7" wide wheels however. Neon and stock pt wheels are only 6" wide. I can't remember what size tires go with 15" cruiser wheels.
2006 PTGT with 5spd. ~60k miles
Old 30 Aug 2013, 12:56 am
Thanks! My 05 PT has 195/65/15 on it now with just hubcaps and I got a great deal on 4 OEM 15" aluminum wheels from an 04 Neon. Just wanted to upgrade to a nicer wheel than the basic wheel I have now.
Old 04 Sep 2013, 02:44 pm
Angry Re: Dodge Neon rims
Well I got my new rims from the 04 Dodge Neon and had them mounted to new tires and put them on the car and they look great but unfortunately they won't work due to the fronts rubbing the brake calipers! I called a tire shop and they were totally against me adding a spacer to the OEM wheels to offset it so there is no rub. Guess my brother gets a free set of wheels for his car!
Old 04 Sep 2013, 03:45 pm
cruserdad1976's Avatar
well not to be a jerk b ut a 1/2 spacer is not goig to hurt anything you are not changing the bolt pattern just getting some needed clearance tire shops are usally aginst anythinng they didnt think of or can make money on
Old 04 Sep 2013, 04:10 pm
InfernoGT's Avatar
This is strange. Is your cruiser a GT or Limited Edition w/ 2.4L Turbo? If so, they have bigger calipers on the front. I don't know much about non-turbo oe calipers. I thought they were the same as the neon to be honest. It's hard to tell by the photo but if they barely rub its possible to grind down where they rub. A member on this forum had to do the same thing to make 19" Caliber SRT wheels fit.
Here's the link: Caliber SRT wheels on a PT Turbo!!!
Old 04 Sep 2013, 05:18 pm
Hey a 3/16 " spacer is all you would need and would not have any affect on anything. Its done all the time. If it were 16" wheel. No problem. Wasn't aware you were going 15" aluminium. But the spacer will be safe.
have a chance to get somr neon srt4 rims jrbsr05pt Exterior Accessories Forum 8 16 May 2012 12:48 am
Neon RT Rims on PT ejui85 General PT Cruiser Discussions 6 03 Nov 2011 06:30 pm
any one with neon... GTcamster General PT Cruiser Discussions 3 27 Apr 2003 03:15 am
Neon? turbomangt Interior Accessories Forum 16 02 Feb 2003 03:24 pm
