What is this thingy?
Like Tree2Likes
  • 2 Post By randyincctx
Old 10 Jan 2014, 08:23 pm
Default What is this thingy?
Hello all! I have a 2005 Pt Cruiser Convertible (2.4L Turbo) and I was doing a radio mod when I noticed this thingy in the first picture that I do not know the purpose of. It is connected to the convertible top motor switch and it is mounted in a rectangular hole in the bottom of the center dash, right above the cubbyhole and cup holders. It has a rectangle of a blue piece of translucent plastic in it. It does not emit any light, or seem to really have any purpose at all. Is it a sensor for something?
In the second picture is another thing I do not know the purpose of. It is a connector plug that plugs into the same bar with with the convertible switch, but it connects to nothing. I am assuming it is for a switch on either a GT or non-convertible? I am interested to know what these two things are for. Thanks!
Old 10 Jan 2014, 08:56 pm
randyincctx's Avatar
Post Re: What is this thingy?
The first photo is the 'Center Console Flood Lamp'(it's not working because your bulb is burned out!),it normally takes a #37 bulb,if you would like it to be brighter you can use a #74 bulb(same as Ins. Cluster),or if you want it REALLY bright you can use a #2723 bulb,and the second photo is the 'dead plug' for the 'Traction Control Switch'(which your PT doesn't have).....
SEE: Hole In Dash?
Aka:~KILLER~
Old 11 Jan 2014, 09:15 am
Default Re: What is this thingy?
SEE: Hole In Dash?
Even if bulb isn't burned out, it's hard to tell it's working - I think a lightning bug puts out as much light...
Old 11 Jan 2014, 04:52 pm
Cool Re: What is this thingy?
That's why I decided to try the #74 instead,and you can tell it works now.....But,if I decide it's not enough I still have 5 of the #2723 bulbs left from when I put them in my instrument cluster.
Aka:~KILLER~
Tags
convertible, sensor, switch, wiring harness
What's this broken wheel/suspension thingy??? konadave Wheels, Tires, Suspension 24 05 Aug 2013 06:53 pm
Pan "thingy" hanging wishiwasyou333 Tech & Performance Forum 7 17 Jun 2013 05:58 pm
pulsating thingy JVZL1 Tech & Performance Forum 10 12 Dec 2011 06:16 pm
Plastic thingy applepiemommy Interior Accessories Forum 7 09 Apr 2011 09:17 pm
anyone ever used this fuel saver thingy? comPuTer General PT Cruiser Discussions 10 04 Jan 2004 02:14 am
