Help with mounting a small safe on rear floor
Like Tree4Likes
Closed Thread
Old 17 Jan 2014, 03:13 pm
tpsfoto's Avatar
Default Help with mounting a small safe on rear floor
Hi all,
Does anyone know if there is anything under the rear floor, drivers side, center partially under the seat. I want to mount a small safe and didn't want to drill until I got more info.
Thanks
Larry
tpsfoto@gmail.com
2005 Plum Vert GT Turbo HO
Nav, Chrome 17" Wheels 5 Speed
K&N Typhoon Air Intake, AOOgah Horn, Freedom Design Strut Tower Brace
Some chrome here & there....
2009 PT bought with Cash For Clunkers.....sold it for a
2014 Juke
Old 17 Jan 2014, 03:38 pm
Default Re: Help with mounting a small safe on rear floor
Originally Posted by tpsfoto View Post
Hi all,
Thanks
Larry
Larry, if you'll simply jack up the rear side of your car as though you were going to change the tire, but then slide under it and you'll very quickly answer your own question, up close and personal. You would have to get under there anyway during your install ( if indeed you can fit it in) so doing so will give you some idea of what you'll be up against during the install.
Use a jackstand if you have one.
Jerry
Old 17 Jan 2014, 03:46 pm
tpsfoto's Avatar
I was going to use the safe company self taping screws right on the floor board.
I will jack it up and look.
Thanks
tpsfoto@gmail.com
2014 Juke
Old 17 Jan 2014, 04:10 pm
You know banks rent out safety deposit boxes
The border Dogs will sniff out the contents anyway......
Busa_Powered likes this.
Old 17 Jan 2014, 05:14 pm
tpsfoto's Avatar
It is not for money or cash .....sometimes I just can't take something into schools or public buildings etc.
tpsfoto@gmail.com
2014 Juke
Old 17 Jan 2014, 05:15 pm
remove the seat, jack up the car, mount an 1/8" or thicker steel plate under the floorboard. it should be at least 1" larger than the safe in all directions. you bolt this through the floor with carriage bolts with the round heads facing down and the threaded parts inside the actual safe. if i wanted your safe and it was held in with self tapping screws i'd be laughing at your stupidity while i pried it out with a flathead screwdriver. don't be lazy. take the time to do it right. seriously.
floors are soft. hell i'll cut a whole car up and have it in the back of the van in two hours. think about it.
Old 17 Jan 2014, 05:45 pm
I don't think I would even "hint" what would go in a safe box like that on an open forum?
Old 17 Jan 2014, 05:46 pm
Ahhh yes. I run into that same problem every day.........I just dont go there, where my friend isnt allowed, I do not patronage ;-)
Old 17 Jan 2014, 05:51 pm
http://www.ptcruiserlinks.com/forum/...r-parents.html
pluminator likes this.
Closed Thread
Side-Rear Fixed Window (the small ones) Wind Noise TheAnt General PT Cruiser Discussions 9 26 Jan 2017 02:58 pm
Control Arm Rear mounting bolt? pluminator Wheels, Tires, Suspension 2 07 Jan 2013 02:56 pm
Small dent in rear quarter panel Travzmakesariot The Detail Shop 3 19 Sep 2010 02:04 pm
Rear Swaybar parts & mounting help please Cal Cruzer General Turbo Discussions 5 22 Jan 2004 05:24 pm
