Idle very ruff
Like Tree2Likes
  • 2 Post By Busa_Powered
Old 13 Apr 2014, 11:30 am
Default Idle very ruff
2006 chrysler pt cruiser convertible 52000 miles, why does my sitting my car at a light idles ruff like it's about to shut off? Please help
Old 13 Apr 2014, 12:21 pm
Default Re: Idle very ruff
Plugs and wires ever been changed?
Make sure engine fan works.
You might have an intake manifold leak.
Old 13 Apr 2014, 01:01 pm
Perhaps you have a dog in your engine
They have been known to be ruff-ruff
Old 14 Apr 2014, 04:00 pm
Are you getting and check engine lights? I am in the process of getting mine fixed. We found that it is likely the lower intake manifold gasket on my car. I already replaced the upper before we confirmed the leak on the lower.
Old 16 Apr 2014, 09:50 pm
Is the engine light on?
You may want to try the "key trick" or "key dance" How to retrieve fault codes. and retrieve a code if there is one.
You then can post the code on here and we can further troubleshoot the problem.
2001 Pt Cruiser Limited (white), Bosch Iridium plugs/wires
Old 16 Apr 2014, 11:56 pm
randyincctx's Avatar
Question Re: Idle very ruff
Does your issue occur with A/C on,off,or both?
Aka:~KILLER~
Running ruff and no idle Psletmein Tech & Performance Forum 17 15 Sep 2013 11:23 am
need advise on ruff idle and cylinder misfire nomadman1956 Tech & Performance Forum 4 22 Jul 2012 11:30 pm
Ruff and shaking ride Cindy2004GT General Turbo Discussions 2 21 Jun 2012 05:25 pm
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
ruff idle rp12bar Northwest PT Forum 1 26 Sep 2008 04:40 am
