Topping off the hydraulic fluid in the motor for the top?
Like Tree3Likes
  #21 (permalink)
Old 09 Nov 2017, 01:14 pm
Default Re: Topping off the hydraulic fluid in the motor for the top?
I purchased the complete kit with core exchange from TopHydraulics. Had a local technician install the parts. Total cost, after core exchange, was approx. $1100.00. Top works great. Very happy!
https://www.tophydraulicsinc.com/en/7-mercedes-benz
  #22 (permalink)
Old 09 Nov 2017, 07:01 pm
Everyones got great ideas on how they fixed theres, and the comments are appreciated, but still nobody has said what they used for fluid to refill the pump? I see someone else asked that question and didnt get an answer. Does anyone have that answer please, so I can at least figure out if i have a leak or the pump is shot. Thanks, Vince
  #23 (permalink)
Old 10 Nov 2017, 06:42 pm
Azrak's Avatar
I researched a long while on the internet before deciding that the hydraulics were made by Mercedes-Benz for Chrysler, and the recommended fluid was Febi 02615.
I bought mine here: amazon.com/Febi 02615
You don't have to drill any holes in the reservoir as I've seen some said they did. There is a fill port on the top of the pump.
It's just not very easy to get the fluid in.
I used a very small tipped pipette and it has to be squirted in the direction of the arrow towards the reservoir.
Rayvin60 likes this.
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
  #24 (permalink)
Old 10 Nov 2017, 07:23 pm
Default Convertible fluid
Saw your post on the fluid. Thanks. Everything else I was aware of, just needed to know what to put in. Will track some down. Thanks again!
  #25 (permalink)
Old 10 Nov 2017, 07:38 pm
Thanks for the info. Found some on ebay.ca, as Amazon.ca does have it. Have dental curved syringes to fill it.
Thanks again, and will post the outcome.
Hydraulic hand brake mod cruisin03pt Tech & Performance Forum 21 11 May 2015 12:20 pm
Hydraulic lines on steering rack DenisMcG Wheels, Tires, Suspension 0 29 Dec 2013 08:41 am
Hydraulic Handbrake mod cruisin03pt Interior Accessories Forum 1 06 Dec 2012 10:53 am
Hydraulic Jack Placement Busa_Powered General PT Cruiser Discussions 10 22 May 2012 08:58 am
Hydraulic Clutch Problem? mmatrix Tech & Performance Forum 25 25 Jan 2012 01:04 pm
