Air Box ?
Old 30 Aug 2014, 07:38 pm
Default Air Box ?
Need some help. How do I remove the stock air box on an 07 convert ? It seems the fuse box is in the way. I want to make my own intake but need to take out the air box. Thanks for the help!
Old 30 Aug 2014, 08:21 pm
Default Re: Air Box ?
if it is the same as my 05 touring, you have to remove the hose and filter. remove the bolts in the bottom of the airbox, then kind of pull and twist and it should come out from under the fuse box.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 30 Aug 2014, 08:30 pm
LionPT's Avatar
I have a 2006, just unhook the hose at the bottom left of the box & the intake hose...than pull up & it will come out..it is not bolted in.
Old 01 Sep 2014, 09:14 am
Thanks for the info. Question, does the hose at the bottom have to stay, or can it hang loose?
Old 01 Sep 2014, 09:38 am
Ummmm....... now that i think about it lion, i think your right. i may have been thinking about the battery tray/bracket. oops!! sorry.
Old 01 Sep 2014, 09:49 am
LionPT's Avatar
I'm not sure...your gonna have to wait for a user that uses the K & N to reply.
You have a 2005, yours might be bolted.
Old 01 Sep 2014, 10:00 am
i can't recall for certain now. been in that thing enough times i should remember.
Old 01 Sep 2014, 11:24 am
soonercruiser's Avatar
Talking Re: Air Box ?
Yup!
The memory is the second thing to go!
(I can't remember what the first one is....)
Frank, aka SOONERCRUISER,
Old 01 Sep 2014, 11:27 am
the water pump?
Old 03 Sep 2014, 11:25 am
it slips onto a bracket shared with the fuse box, but it is not bolted to it. it will just pull off. pull straight up. be mindful of the inlet duct at the lower corner feeding from the wheelwell.
1-Disconnect the throttle body air inlet hose/ clean air hose from the air cleaner housing
2-Pull air cleaner housing straight up to remove.
3-Remove the inlet duct from the air cleaner housing.
when you make your own tube, you can attach the little valve cover vent hose to your tube, or stick a little toy filter on it.
