Steering wheel replacement
Old 22 Sep 2014, 01:51 pm
Default Steering wheel replacement
Has anyone got any experience in the removal of a pt cruiser steering wheel, I'm interested in the airbag removal and how it affects the on board computer and any warning lights,
Does anyone have experience of perhaps a by pass for the airbag.
Thanks andy in the uk
Old 22 Sep 2014, 03:30 pm
Default Re: Steering wheel replacement
it will turn your airbag warning light on and you'll fail any inspection the government may make you take there.
you may be able to find a creative way to keep the light off using resistors, but i've never seen any instructions on doing that. for example, here's a volkswagen guide: http://www.users.on.net/~quozl/PDF/A...or%20Guide.pdf
you might try measuring the resistance of the airbag with a multimeter, then go buy a 0.5w resistor of that value. i'd be afraid to try it though. connecting it wrong may deploy the other air bags.
Old 22 Sep 2014, 04:56 pm
harrym's Avatar
I had my steering wheel replaced with no ill effects. Don't ask me how they did it. I just know it can be done. It must not be too complicated, because the garage only charged me 20.00 or so to do it.
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Old 23 Sep 2014, 01:34 am
ptgrotje's Avatar
Send a message via MSN to ptgrotje Send a message via Yahoo to ptgrotje
With what do you want to replace it? Something old maybe?
www.blackcruiser.nl
My site is in English too
Old 24 Sep 2014, 01:48 pm
Thanks for the replies, I was going to replace it with an polished dark oak model, with the horn button still in the middle. But having looked deeper I can't find any instructions on how to bypass he airbag part this as you say the warning light will be on, thus fail a uk yearly test (mot).
Surely someone has done it.
Old 24 Sep 2014, 02:00 pm
This sounds like only a stock wheel replacement.
There is not really away to do an aftermarket in less than 2-3 hours or more if you want to retain the cruise control.
If you disconnect the battery and wait 5 minutes or more the air bag can not deploy.
There is a couple ways to replace the airbag and keep the system active. The resistor is the most common way. If you measure the ohm of the sir bag and than get a one way resistor with the same ohms it should keep the system active. Another way which is really a better idea is with an adjustable ohms Potentiometer . This way you can get the exact ohm resistance through the system. The down fall is if you mess up with either way the air bag will missing will activate a warning light and the system will be inactive until re-set.
I doubt that anyone will tell you what resistor to use for fear of being wrong besides I would not trust anyone information regarding this anyway.
Old 24 Sep 2014, 02:09 pm
Good Luck!
How to: Aftermarket steering wheel
Old 24 Sep 2014, 08:37 pm
harrym's Avatar
yes, it was basically a stock replacement. The original wheel was showing wear, and I found a leather wrapped wheel on eBay. I think the leather wheel was from a GT. It has silver spokes. The leather wrapped wheel on my son's '03 Limited has black spokes. Just trivia.
Harry
harrym's Avatar
Yes, it was basically a stock replacement. The original wheel was showing wear, and I found a leather wrapped wheel on eBay. I think the leather wheel was from a GT. It has silver spokes. The leather wrapped wheel on my son's '03 Limited has black spokes. Just trivia.
Harry
Old 02 Nov 2014, 06:34 pm
Please do not use a multimeter to check the air bag resistance as suggested below as it will set off the air bag.
"you might try measuring the resistance of the airbag with a multimeter, then go buy a 0.5w resistor of that value. i'd be afraid to try it though. connecting it wrong may deploy the other air bags."
2nd, There is a specific sequence of events listed in the manual for replacing the air bag which involves the use of a DRBIII scanner (Code Scanner).
First disconnect the negative (Ground) wire from the battery for at least 20 minutes.
a. Connect the cone scanner to the diagnostic connector (below the steering column)
b. Turn the ignition switch to the on position (not start)
c. Make sure there is no one in the vehicle and reconnect the ground battery negative (ground) wire (cable)
d. if the air bags did not go off... good, now use the scan tool to note any diagnostic codes and refer to the relative data if any fault codes exist.
e. Erase any stored fault codes (if there is a problem the codes will not erase)
f. reach round behind the steering wheel (to the front of the steering column) and turn the ignition key off then turn it back on
1-Look at the airbag indicator light on the dash panel
2-It should turn on for 6-8 seconds then go out
3-This indicates that the airbag system is working properly
If the airbag lamp test fails there is a malfunction which must be determined and repaired. (see the scanner codes)
If the airbag lamp test passes:
Turn the key off and remove the scan tool
1-Test that the horn is working
2-Test that the tilt mechanism works
3-Road test the vehicle
Hope this helps the folks across the pond
Steering rack replacement dklipfel Turbo Wheels/Suspension/Handling 8 01 Jun 2013 11:22 am
replacement power steering pump nomad327 Tech & Performance Forum 1 05 Mar 2013 06:42 am
wheel skin steering wheel cover chintzgirl Interior Accessories Forum 0 23 Oct 2010 08:05 pm
Power Steering Sensor replacement JJ1 Tech & Performance Forum 0 19 Jul 2009 11:22 pm
steering rack replacement linda General PT Cruiser Discussions 6 11 Jan 2004 11:30 pm
