Timing Belt Replacement....
Old 11 Dec 2014, 01:50 am
Red face Timing Belt Replacement....
I have almost 90k on my 2007 convertible, and I checked my owner's manual and the maintenance service and can't find anything about when the timing belt should be replaced. I am sure it has to be prior to hitting 100k. Thanks!
Old 11 Dec 2014, 02:25 am
Default Re: Timing Belt Replacement....
In my 2007 PT Cruiser Convertible owners manual it says that the timing belt should be replaced at 102,000 miles. Its under maintenance schedule if you look in the back of the manual.
Old 11 Dec 2014, 08:32 am
Thanks!
Old 11 Dec 2014, 11:22 am
cruserdad1976's Avatar
has anybody to;d you how much that puppy is to replace??? most are between $750--$1000 unless you are a diyer
Old 11 Dec 2014, 01:58 pm
rckstein's Avatar
And the other wearable components under the front cover, you don't want to have to tear into there again!
Old 11 Dec 2014, 03:21 pm
We have some great how to on the subject. Good time to study up on it. Plus all the other help listed there.
Old 11 Dec 2014, 08:42 pm
soonercruiser's Avatar
Cool Re: Timing Belt Replacement....
Personally, especially after seeing a few recent posts here about bent valves, I would not let any of my Cruisers go past 90K with replacing the timing belt, water pump, and tensioners.
Then's also a good time to access the motor mounts!
Bought a used Dream Cruiser last fall with 93K! Did the timing belt the first thing!
Frank, aka SOONERCRUISER,
Old 09 Mar 2016, 03:08 pm
My 2003 Dream Cruiser with 82,000 miles is in the shop waiting for me to go get it. Timing belt, water pump and 3 motor mounts replaced at just under $1,500. Yikes!
Old 09 Mar 2016, 03:14 pm
rckstein's Avatar
That's about the going price. Did they replace the tensioner, idler pulley, cam and crank seals while they were in there?
Old 10 Mar 2016, 10:06 am
Yeah, like rckstein said, that's about right. Paid $1306 to have the timing belt kit (including tensioner and idle pulley), water pump, ac and alt belts, and upper and lower mounts done on my '05 Vert GT. Didn't do the camshaft or crank seals or the 3rd engine mount, though...
Timing belt replacement snakepitt1 Tech & Performance Forum 10 18 Dec 2016 12:17 am
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Timing Belt Replacement - What Next? johnjsa Tech & Performance Forum 5 22 Feb 2012 05:22 pm
timing belt replacement on 01 pt notme Tech & Performance Forum 8 14 Nov 2009 07:43 am
Timing Belt Replacement? Kawika Tech & Performance Forum 14 15 Dec 2007 11:56 pm
