Replacing The Convertible Top
Like Tree7Likes
  #11 (permalink)
Old 19 Oct 2017, 02:52 pm
Cool Re: Replacing The Convertible Top
I'm a new PT owner. Bought a 06 Turbo. Got a good deal because the top is ripped. I was going to patch but got lucky and found a like new top at the scrap yard. We pulled everything even the motor for it. So frame and all. It was a bitch to get off, took us over 2 hours. I'm wondering if there is an easier way to connect just part of it, then save the left overs for parts. We had to remove so much of the inside of the car to get it out. Don't want to tear mine apart to get it in.
  #12 (permalink)
Old 19 Oct 2017, 03:03 pm
  #13 (permalink)
Old 15 Feb 2018, 07:13 pm
Default Re: Replacing The Convertible Top
I am wondering if there is an easy way to replace the top without having to actually use the entire frame if that makes sense. I know the framework goes down inside and I'm wondering is it possible to replace just what you see that's above the car so you don't have to take things apart. I have a new top to put on mine that has all the framework already on it but I want to be able to do it as easy and as quickly as possible has anyone ever just undid the bolts on the upper part of the mounting and hooked it on there without replacing the entire frame? Sorry if that doesn't make a lot of sense I'm not sure of the technical names for it.
  #14 (permalink)
Old 15 Feb 2018, 07:46 pm
rob302's Avatar
Your post makes sense, but you need to understand that Chrysler was CHEAP and cut corners everywhere possible. Like down to to saving a penny per car. The only thing I could imagine leaving out would be the stuff that makes it open automatically. I recommend you just suffer through it once, do a good job, and hope it lasts a while.
  #15 (permalink)
Old 15 Feb 2018, 08:03 pm
My02RedRide's Avatar
I have deleted my original post as to not start trouble. End of story.
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
  #16 (permalink)
Old 18 Feb 2018, 05:59 pm
rob302's Avatar
Originally Posted by My02RedRide View Post
I have a major problem with your statement on saying "Chrysler was CHEAP and cut corners everywhere possible"..... did you work there ? If you DIDN'T then don't say those comments please..... I don't appreciate them.
well they did strip features and remove parts year by year. lights in stwitches, trim round the glovebox, the rear swaybar, etc etc etc. they went as far as to discontinue the fluid my trans took(which is very similar to 5w30 with a synchro additive)and told me to use ATF4 instead because then they save money cutting back on a fluid.
if you don't like it i don't care, and neither did they.
  #17 (permalink)
Old 18 Feb 2018, 07:08 pm
[QUOTE=rob302;682689]well they did strip features and remove parts year by year. lights in stwitches, trim round the glovebox, the rear swaybar, etc etc etc. they went as far as to discontinue the fluid my trans took(which is very similar to 5w30 with a synchro additive)and told me to use ATF4 instead because then they save money cutting back on a fluid.
Deleted original post as to not start a war............
CRUZ and rob302 like this.
  #18 (permalink)
Old 18 Feb 2018, 07:25 pm
Talking Re: Replacing The Convertible Top
I sure like my PT. Cruiser. Mine is a 05 convert.
  #19 (permalink)
Old 18 Feb 2018, 09:44 pm
rob302's Avatar
Then sell the cheap, stripped down piece of JUNK and buy a different brand and proceed to hate that one too....... sounds like you never worked for the company and have NO CLUE on what was going on under the "merger of equals Daimler days".
As for the trans fluid in the manual trans, the original fluid that was spec'd was VERY expensive and after hundred of hours on a numerous trans dyno and road miles it was determined that ATF+4 was a very acceptable alternative. Have you had a failure in your trans because of the ATF? Use the 5w30 Mobil 1 or better yet go find the original Mopar trans fluid for that trans then I'll hear you piss and moan that IT COSTS TOO MUCH.... waaa waa waa cry me a flippin river
seems you're the one doing the crying. i did ditch he pt. **** that car. **** you. and **** this forum. sick off all you cranky old assholes. eat a bag of dicks.
  #20 (permalink)
Old 20 Feb 2018, 05:54 pm
ROB302, I need to apologize to you and others on this forum who look at what was posted between you and I. I realize and appreciate your position and understand your opinion of features that were removed for "certain reasons" and I have to agree and with that comes a passion for vehicles one has "worked" on. I took your words too close to heart and shouldn't have. Yes I'm an OLD FART, crochety old bas**rd yet everyday understand other's passion / dislike for their rides. sincerely
Replacing a PT top.... iBorg PT Cruiser Convertible Forum 0 29 Sep 2013 08:50 pm
Replacing Convertible Top mbelleville PT Cruiser Convertible Forum 10 05 Jul 2013 10:32 am
replacing TCM Bentron General PT Cruiser Discussions 15 19 Jun 2011 03:17 pm
replacing Cat omaolain General PT Cruiser Discussions 7 05 May 2010 08:27 pm
PT Convertible beats VW Convertible PlasteredDragon General PT Cruiser Discussions 3 09 Aug 2004 01:28 pm
