Top and Window fuse?
Old 13 Jan 2015, 08:41 pm
Default Top and Window fuse?
I have a 2005 PT Convertible . Just had a dead battery. I mean really dead! Replaced the battery and almost everything is fine. But the Convertible Top and Windows will not function (go up and down). I figure it is a fuse but my manual doesn't show any number for those two items.
Before a check every fuse I thought I would check and see if anybody has the fuse number (I assume it is on the interior fuse block).
Thanks for the help.
Old 13 Jan 2015, 08:46 pm
Default Re: Top and Window fuse?
I've heard this before. There's a procedure you have to do to get everything working. I'll see if I can find the threads that talk about it or maybe someone will see this and post it for you.
I'm back...try this...
Window problems
Driver window auto close??
Old 13 Jan 2015, 09:36 pm
soonercruiser's Avatar
Cool Re: Top and Window fuse?
Please let us know if these "fixes" work FOR YOU!
Frank, aka SOONERCRUISER,
Old 13 Jan 2015, 10:34 pm
There is a service bulletin 08-03-05 that may help with this problem with the smart glass module.
Old 14 Jan 2015, 11:30 am
I will give this a try this evening and let you know. I found the service bulletin and printed it out.
Thanks.
no Fuse problem and not iod fuse ptcarter Tech & Performance Forum 24 09 Jul 2013 03:21 am
window fuse location? imaram2 General PT Cruiser Discussions 9 30 Jul 2012 08:56 am
Cleaning window panel piece that's not the window itself(whatever you call it) angel66rose The Detail Shop 2 08 Feb 2012 11:21 am
HELP with Wiring Fuse 7 (No feed to fuse) No A/C, Electric Windows, Rear fogger??? ptcruisershoreham General PT Cruiser Discussions 3 08 Mar 2011 08:06 pm
Window Mirror Issue Window won't go up georgebIV General PT Cruiser Discussions 2 09 Aug 2009 01:17 pm
