My baby's angry and wont start
Like Tree4Likes
Old 02 Mar 2015, 04:06 am
PTCruzing's Avatar
Exclamation My baby's angry and wont start
Hello everyone!!!!
It's been awhile I need some help and probably should have come here sooner. It all started with a squeaky alternator belt which i had replaced on my 2005 pt convert turbo. After a couple of weeks leaving work my gauges and lights were acting funny.
The car ended up leaving me stranded as the car just died at a light and would not turn over. I had it towed to the shop and my mechanic said the belt to the alternator was lose. He tighten it up and tested the alternator and battery, and said they were good.
He then said there was a new problem the gas gauge would go to full then to empty. (P0462) I asked if i could drive it like this until i could bring it in and he said yes. A week later i go to start it and didn't turn the key all the way as it almost started. I go to turn the key again and nothing, no clicks, no turn over, NADA. Here's where things get crazy.
I get a jump and the car starts. I then turn it off and try to start it and nothing. Lights and radio work fine but no turn over. I then get a jump again but this time the car starts but when we remove the jumper cables my car turns off???? The following are things I've done.
[LIST][*]Changed the alternator--- the old one tested good[*]Changed the battery---- the old one tested good but was 3 years old[*]Changed the starter--- the old one tested good[*]Checked cables and fuses all look good[*]Checked relays all test good[*]Changed the ignition switch-- didn't work and now get a error code of (p0513) tomorrow i will hope to reset with unplugging of battery. We'll see.
Car has been running like a champ and all of a sudden no love!!!!! Im running out of options. Tomorrow i will check if there's a Fusable link and continue my frustrating journey.
Any and all feedback would greatly be appreciated. Frozen grease MONKEY in Chicago burbs
Thanks!
Old 02 Mar 2015, 05:23 am
Default Re: My baby's angry and wont start
Since it started with a jump, your grabbing the outside of the battery cable ends, I would bet you either need to clean the battery connections or replace the the cables. Check to make sure they are PERFECTLY CLEAN and tight first.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Mar 2015, 08:59 am
Handy_Cruiser's Avatar
Yep.
This all sounds like a bad connection somewhere. Even the gas gauge can act funny if the voltage is not right.
Clean both battery cable ends really well. Also, check where both battery cables attached to the car. The positive lead should run to the starter and the negative will ground to the frame or engine somewhere. It's very possible that there is a bad connection at one of these ends.
Old 02 Mar 2015, 09:20 am
I would suggest you might have an invalid Skim key.
Do you have an spare key to try?
On the replacement of the ignition switch what was replaced ?
P0513 - Invalid SKIM Key Detected
Trouble Code Conditions:Key on, and the PCM detected an invalid Sentry Key Immobilizer key had been inserted into the ignition key assembly.
Possible Causes:
Incorrect VIN in the PCM
No communication between the PCM and the SKIM
SKIM trouble codes present (check for any SKIM codes)
Valid SKIM key not present
VIN not programmed into the PCM
PCM has failed
Old 02 Mar 2015, 03:30 pm
PTCruzing's Avatar
Thumbs down Re: My baby's angry and wont start
First off thanks for all the feedback. Here's an update. I had a mechanic stop by and he thought he found the problem. The cable that connects to the solenoid showed no activity when testing. He then ran a cable from the solenoid to the battery I believe and the car sounded like it wanted to start.
So, he clipped off the connector and replaced it with a new one and it tested good. Plugged it in and crossed my fingers, turned the key and nothing, no turn over at all, no clicking sounds, nothing.
I did reset the battery and do not get the P0513 anymore. I provided the mechanic all the feedback I received thus far. He thinks it maybe the security system that comes with the car, the computer, or the key preventing it from starting? He seemed confused as I was. Running out of ideas.
My baby is really angry with me....
Old 02 Mar 2015, 04:02 pm
Humm....
Old 02 Mar 2015, 06:19 pm
Did you replace the starter with a new starter or a "rebuilt" one? Some people have had several bad "rebuilt" starters in a row.
Old 02 Mar 2015, 07:56 pm
PTCruzing's Avatar
It was a rebuilt one. Advanced auto was the only place in my area that had 1 left. I bought it as I wanted to have my car running before today. So much for that wishful thinking. All parts stores said they could have a new one by Wednesday. I'm about to throw in the towel and have it towed to the shop. Just so frustrated with the car right now.
Old 03 Mar 2015, 12:25 am
Possible Causes:
PCM has failed
Did you try a spare key?
Some PT Cruiser owners have had a bad solder connection on the board in the Security Key Module.
You need to eliminate the possibility that the security system is keeping the PT Cruiser from starting.
Old 03 Mar 2015, 12:52 am
PTCruzing's Avatar
When I bought the car it only came with one key. So, no spare
pt wont start gee77060 Tech & Performance Forum 13 13 Nov 2014 09:14 am
Sometimes wont start. Annie_Melody Tech & Performance Forum 17 16 Feb 2013 10:27 am
04 pt wont start penstar66 General PT Cruiser Discussions 6 01 Sep 2010 02:27 am
help my baby blue (pt cruiser)wont start!!!! pttapp Tech & Performance Forum 2 12 Apr 2010 02:53 pm
07 TE PT wont start PLEASE HELP!!!!! Norma Tech & Performance Forum 10 08 Dec 2008 08:58 pm
