Should I replace my '05 Turbo Convertible engine?
Like Tree3Likes
Old 28 Mar 2015, 01:30 am
Default Should I replace my '05 Turbo Convertible engine?
At 115K, I have end play on my crank and have fried my #4 cylinder. There's metal in my oil, I'm throwing smoke on startup and hear a whine from deep in the engine. My car is very clean, has new A/C and radiator, plus a new $2500 top. They want $11,000 to replace the motor and turbo. I love this car, but shouldn't I just move on?
Old 28 Mar 2015, 06:10 am
LionPT's Avatar
Default Re: Should I replace my '05 Turbo Convertible engine?
Shop around for a better price. PM 'NitroPT'.
Old 28 Mar 2015, 08:42 am
767skyking's Avatar
Originally Posted by BigJim333 View Post
At 115K, There's metal in my oil, I'm throwing smoke on startup and hear a whine
Sound like you have a bad turbo... How did they know that #4 cylinder is blown?
Busted_PT likes this.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 28 Mar 2015, 10:28 am
$11,000 is outrageous.
You could buy a beauty for a lot less - here's just one:
NEW PRICE! Refurbished 2005 Dream Cruiser Series Convertible
Old 28 Mar 2015, 02:23 pm
Thanks for the advice, guys. Via a tiny TV cam, they showed me the scoring in #4, plus there are metal shavings in the oil. The idea that a leak in the intake manifold caused #4 to go lean and overheat. The crank end play is just a poor design flaw.
And yes, I'm looking around for a better price.
Old 28 Mar 2015, 03:07 pm
xwing777's Avatar
Plenty of choices on used or rebuilt PT and SRT4 engines on ebay. Some with warrantys pt cruiser turbo engine | eBay
Old 28 Mar 2015, 03:18 pm
Agreed, $11K is outrageous. You could buy 2 replacement complete cars for that! Find a low mile junkyard complete engine and swap it in or look on ebay as suggested or something. You could even buy a semi wrecked car that is still running and driving and pull the motor out after you have tested it. Lots of options besides forking over 11 thousand!
Old 28 Mar 2015, 03:23 pm
Handy_Cruiser's Avatar
Where I live, a 2005 PT Turbo Lite convertible is worth between $3,000 and $4,000. And possibly less. The only way to repair this car from a cost perspective is to swap in a used engine from a salvage car. And still, if you have to hire it all done, you will be lucky to get out under $2K. In your situation, it might be better to sell the car on Craigs list with the blown engine for $1,000 to $1,500 and then put that with the money that the repair would cost and buy yourself another car.
The sad truth is that if you cannot do the work yourself, owning any car that is ten years old or older can get very expensive if a major problem occurs.
Old 28 Mar 2015, 03:58 pm
Wow, this forum is the best. Thank you all for your suggestions. I will definitely check out eBay, and I'm glad to hear that I might bet $1000 to $1500 for a clean car with a blown engine. I think my Plan A, however, will be to go back to the original mechanic and another one with a $4K proposal to do everything except the turbo and recently-replaced radiator, water pump, etc. Otherwise, I'll have to buy another car.
Old 28 Mar 2015, 04:21 pm
767skyking's Avatar
Jim... what part in LA do you live? I can set you up with a good place that can trouble shoot the car and give you a "real" estimate on repairs!
dougs and Handy_Cruiser like this.
Rust on PT convertible----replace panel or cut/patch/sand? kpl1228 The Detail Shop 4 14 Apr 2015 07:00 pm
Remove & Replace engine oil cooler on a 2004 PT turbo? johnchilders General Turbo Discussions 5 03 Jan 2014 03:29 pm
Engine repair or replace advice mecheng87 Tech & Performance Forum 7 07 Jan 2013 02:28 pm
Repair or Replace Turbo Engine-Non Turbo? Ikster General Turbo Discussions 17 07 Feb 2012 12:28 pm
$3,000 to replace engine? dmellen07 General PT Cruiser Discussions 5 03 Oct 2011 03:32 pm
