2006 convertible dash panel
Like Tree3Likes
  • 3 Post By LionPT
Old 20 Jul 2015, 06:18 pm
Default 2006 convertible dash panel
How does one get the dash panel around the window switches apart for replacement of drivers window switch. It sticks in the down position and one has to remember to push it back up quickly when it does this or you can't operate the window for a few s
minutes. I'm wanting to replace this switch but don't want to break the plastics in the dash to remove it.
Thanks.
Old 20 Jul 2015, 07:29 pm
LionPT's Avatar
Default Re: 2006 convertible dash panel
There are 2 screws, 1 each behind the vents.
Spin the vents around till you see a slot, that is the only way to see the screw.
Once both screws re removed, just grab it from 1 side or the top & pull...for me the passenger side always seems easier when sitting in the drivers seat.
Once you pull it out, you will have to unplug the clock & then you can unplug the window switch.
Old 12 Feb 2016, 10:05 pm
WOW,,,,!!!
Timing couldn't have been better,,
And thanks ,,big help with the picture
Old 13 Feb 2016, 02:09 pm
Also you might want to check-out a wrecking yard first for a window switch. new thy run about $84.00 Awhile back I purchased two window switches just incase they cost $12.00 ea I Bought 1 for my 002 and 1 for my 006 they also had money back guarantee return if defective, Also you really don't have to put those two screws back on,the bezel snaps on tight with out them anyway.Best to you.
Old 23 Apr 2016, 12:40 pm
Was about to ask the same question and found this photo showing the screw locations.
Thanks LionPT!
How do you remove the dash top panel? eflyguy The Detail Shop 14 14 Nov 2015 06:14 pm
Painted center dash panel Johnnyjet Interior Accessories Forum 22 17 Aug 2013 09:31 pm
Centre Dash Panel Repaint Jassy General PT Cruiser Discussions 4 09 Mar 2012 03:59 pm
'01-'05 dash switches and panel mopar_man Classifieds: For Sale/Trade 1 14 Sep 2009 04:32 pm
BUBBLES CENTER DASH PANEL KIMS CRUZER General PT Cruiser Discussions 15 22 Nov 2004 11:30 pm
