2005 turbo light speedo markings
  • 1 Post By racerev
Old 01 Feb 2016, 03:30 pm
Default 2005 turbo light speedo markings
Does the turbo light have a 120 or a 140mph speedo? My owner's manual says the turbos have a 140, but is that only for GT's?
Old 01 Feb 2016, 03:55 pm
Handy_Cruiser's Avatar
Default Re: 2005 turbo light speedo markings
The GT got the 140 mph speedometer. The turbo lite did not.
Installing the GT speedometer in the the turbo lite will be problematic since the GT cluster for the automatic is setup for an Autostick shifter. I attempted to install a GT cluster in a 2001 Limited. The gauges worked but the indicator and shifter lights were all screwed up. Recently I found a forum thread on another type of Daimler/Chrysler where the upgrade had been done. If it works the same, you would need the GT cluster, GT PCM, Autostick shifter and then you would need to make the necessary connections from the shifter to the PCM. It's pretty cut and dry on this other car. But I cannot find where anyone has done this on a PT.
Old 01 Feb 2016, 04:28 pm
bubba_1952's Avatar
Do you have an A/T or M/T?
Bubba
2004 Limited Edition Platinum Series Dark Graphite Metallic Clearcoat Turbolight A/T
Old 01 Feb 2016, 04:33 pm
Bubba
I believe all the turbo lites came with automatics.
Old 01 Feb 2016, 04:55 pm
Smile Re: 2005 turbo light speedo markings
Thanks for the clarification. The owner's manual was unclear on the question.
Handy_Cruiser likes this.
Original timing belt brand/markings Jfirey General PT Cruiser Discussions 5 20 Aug 2015 08:14 pm
2005 turbo 2.4L vibrates when at a red light joelcr3 General Turbo Discussions 16 03 May 2014 10:29 am
2005 PT Cruiser engine light coming on neeter51 General PT Cruiser Discussions 1 04 Feb 2013 10:08 am
RED LIGHT IN SPEEDO?? drumrooster Tech & Performance Forum 1 20 Jul 2011 08:17 am
Markings don't line up Cruz2success Tech & Performance Forum 1 10 Feb 2010 06:59 pm
