Power window problem
  • 1 Post By nomad327
Old 19 Mar 2016, 02:46 pm
Default Power window problem
I could really use some help with this. I have a 2005 convertible with 2.4 turbo. I put top down just the other day. Windows went down like usual. When put top back up later in day all windows went up but passenger widow. All other Windows work as should. All switches are in dash. 4 in the cluster. There's a circuit board inside the switches. I can't find a wiring diagram to help me. I have a 12 volt light tester and can't even find power at the switches. It has to have power cause the others work. I also don't know how to correctly take off door panel to check motor. Although it did go down by motor when top went down. Any help would be greatly appreciated.
Old 23 Mar 2016, 11:44 am
Default Re: Power window problem
I scanned the wiring diagrams and have them on photobucket at link
nomad327's Library | Photobucket
There may be a more simple solution involving a reboot of the system. I would search here for other posts on the subject.
Old 23 Mar 2016, 11:19 pm
You might want to read this TSB and see if it applies to your issue.
http://ww2.justanswer.com/uploads/n9...125719_tsb.pdf
2007 driver power window failure/window stuck down JeffLancia Tech & Performance Forum 5 30 Nov 2015 10:26 pm
Need help with power window msmiamunoz Tech & Performance Forum 1 02 Sep 2013 04:48 pm
Auto Power Window Problem nitrometal General PT Cruiser Discussions 5 26 Jul 2013 08:12 pm
Power window problem droptopman Tech & Performance Forum 2 29 Mar 2010 07:32 pm
POWER WINDOW MOD WAYNEF Interior Accessories Forum 13 13 Jan 2005 05:40 pm
