Major water leaks! Help!
Like Tree7Likes
Old 25 Aug 2016, 02:46 pm
Default Major water leaks! Help!
We've had a lot of rain and the trunk on my '05 gets water every time we get rain. It's starting to get to the rear floorboard during heavier rains. I checked the drain tube at the top of the trunk deck. Seems clear, blew air into it, even poured water onto the top and it drains fine. Still getting water. The top looks fairly new, like it was replaced just before I got the car. I'm thinking they missed something, like a drain tube or pan. Does anyone have insight to this? I can't see anything without removing the top, or part of it.
Old 26 Aug 2016, 02:27 pm
Default Re: Major water leaks! Help!
I may have found the problem, but don't know how to fix it. I have the top down half way and the passenger side of the convertible top is lower against the rear body than the driver side. Is there any adjustment to it?
Old 27 Aug 2016, 08:55 am
If anyone here knows the answer to that, it SHOULD be Handy!
Old 27 Aug 2016, 10:00 am
I took a look on my 2007 convertible top and if you get inside the PT Cruiser and move the strapped cloth in that corner there is a strap coming down from the top that is attached to a bolt. Is your strap still attached to the bolt?
Old 27 Aug 2016, 12:10 pm
Is this what you're talking about?
Old 27 Aug 2016, 12:26 pm
Yes, does that strap still have tension on it?
Old 27 Aug 2016, 12:46 pm
Yes, it's tight
Old 30 Aug 2016, 06:44 am
Still raining, still leaking. Anyone?
Old 30 Aug 2016, 07:49 am
Here's a couple pictures of the back. I found a picture online that looked like someone had a seal visible below the back glass where the body starts. I see no such thing on mine. Anyone with convertibles that don't leak that can get me a picture?
Old 30 Aug 2016, 08:31 am
has the PT Cruiser been in an m minor accident?
P0455 Major Evap Leak Major issue h_wingman Tech & Performance Forum 16 27 May 2018 12:03 pm
Convertible Leaks Water into Rear When Raining - Anyone see this before? 06BlackVert PT Cruiser Convertible Forum 17 11 Oct 2017 08:19 am
Leaks malisa General PT Cruiser Discussions 20 09 Mar 2014 09:13 pm
oil leaks fancy Tech & Performance Forum 5 29 Oct 2011 07:48 pm
Water Leaks? Silverbagger Welcome New PT Cruiser Members 1 18 Sep 2011 06:06 pm
