Convertible chassis stiffening - foam
Like Tree6Likes
Old 26 Sep 2016, 04:58 am
Default Convertible chassis stiffening - foam
Hello!
As my PT convertible´s “scuttle shake” drives me crazy, I´ve been looking for a solution. You know…. the chassis is as “chewing gum”.
I see there is a product named “structural foam”. Chassis voids are filled with this product and it seems that the chassis is stiffened.
Has anyone tried to make a chassis filled with structural foam?
Best regards.
Old 26 Sep 2016, 11:44 am
Default Re: Convertible chassis stiffening - foam
Originally Posted by GT_DESCAPOTABLE View Post
Hello!
Best regards.
Foam will not stiffen your chassy. It will rot it out for you. Your chassis the can't be flexing much. Nothing you could feel. I would suggest to check you components. Bushings bell crank, tie rods, ball joints, end links, even the bushings for the sway bar. These all make noise when worn out. Rear shocks for bounce. Some have had front struts need replaced. Motor mounts makes it feel clunky and loose to. Forget the foam.
SPLNeon likes this.
Old 27 Sep 2016, 11:41 am
Hello.
Thank you for your reply.
I can understand foam is not a solution. All parts you said me were checked; even shock absorbers are new. There is not anything wrong.
It has a pronunced "scuttle shake". Wind screen moves left and right when I take rought pavement....( even steering wheel ) And some reviews said the same.
look:
2006 Chrysler PT Cruiser Cabrio range | GoAuto - Our Opinion
https://www.carkeys.co.uk/review-arc...o-limited-auto
Chrysler PT Cruiser Convertible Buying Guide
Chrysler PT Cruiser convertible review | Autocar
2008 Chrysler PT Cruiser | Ingersoll
..... search in google "pt cruiser scuttle shake". There is a lot of similar reviews.
Thank you for your help.
ps. forgive my poor English.
Old 27 Sep 2016, 05:58 pm
Carnut's Avatar
Heh, heh, yes my 05 GT conv has about as much 'scuttle shake' as the 57 Chevy Conv I once had.
Handy_Cruiser likes this.
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
Old 27 Sep 2016, 06:14 pm
Reading the above, it sounds like Chrysler didn't do a decent job of figuring out how to strengthening the body when the roof is removed. They did add the basket handle but apparently that isn't enough.
On the C4 Corvettes, General Motors ran into the same problem with the verts but someone came up with an "X" frame for the undercarriage and that seems to solve the shake.
Maybe someone could come up with something similar for the PT vert.
Corvette C4 "X" frame.
Now for the chassis that came out before the fix was put on, an aftermarket "X" frame can be had to add to the undercarriage.
Handy_Cruiser and Gkon like this.
Old 27 Sep 2016, 09:02 pm
This could be accomplished right off the k frame rear mounting bolts. Either connect at the mount for the rear axle or the frame rail. Take in account what obstacles that need to be worked around.
Old 30 Sep 2016, 02:01 am
Hello.
I´ve been searching for an X frame for PT Cruiser. There is nothing at all. Of course, unthinkable in Spain... in Spain one PT Cruiser convertible is a rarity. I only see 2 PT convertible in my life: Mine and 2 years ago one beige in road. And too many people said never see one.
Do you know any one x-frame to buy??
Regards.
Old 30 Sep 2016, 08:12 am
Fk5 Fk5 is offline
Might be better off making one. Subframe braces are a fairly common DIY deal for old muscle cars. Rather than an "X" those just run front to rear connecting the subframes. Those cars are RWD and have to worry about the driveshaft. On a PT you only have to worry about the exhaust and some other more minor stuff.
I wouldn't actually do-it-myself, but you probably have a race shop that welds up chassis and cages. As long as they have something to insure that the frame is straight and are reputable it might be the way to go. When you consider the cost of shipping something like an "X-frame" to Spain, it might actually be cost effective to have a shop whip something custom up.
2003 GT 5 speed
162,000 miles
Old 30 Sep 2016, 08:26 am
There is no product available. Custom or none. That being said. In my opinion some 1" tubing should be adequate to do the job.
Old 30 Sep 2016, 02:33 pm
Handy_Cruiser's Avatar
My 2007 convertible is just as solid as either of my previous PT wagons. I've notice none of this problem at all. To be exact, this convertible is the best riding of all there PT's I've own.
Is the OP really sure he doesn't just have bad control arm bushings?
leaking fuel line supply chassis to rail...HELP! Rebuilder General PT Cruiser Discussions 4 26 Jun 2015 05:44 am
leaking fuel line supply chassis to rail...HELP! Rebuilder Welcome New PT Cruiser Members 2 22 Jun 2015 09:01 pm
Broken ground wire from strut to chassis. edscrz General PT Cruiser Discussions 4 14 Dec 2012 09:13 am
Sea Foam method dsmturbo General Turbo Discussions 1 27 Apr 2010 10:09 am
Chassis Lubrication Points 2002ptcruiserwoody723 Tech & Performance Forum 2 29 Sep 2009 09:49 pm
