2005 PT Verte with top leak.
Old 19 Jan 2017, 04:32 pm
Default 2005 PT Verte with top leak.
HELP!! I have a leak that seems to run in between the top to the passenger send them it comes POURING inside car, leaving pass seat, floorboard (front and back) with PUDDLES! !!
If you fell inside of top it is not wet,yet you can clearly see it pouring inside car. Only happens in driving rain or after a good soaking rain.
Is there a seal I should be checking?
Thank you ahead of time!
Old 19 Jan 2017, 05:11 pm
Default Re: 2005 PT Verte with top leak.
Opps.... I thought you had a sedan PT
The seal you see around the glass when it is in a closed position is the only thing to slow water infiltration.
The sunroof should be almost flush with the roof of the car when closed.
The sunroof tracks and cross braces act as gutters for water to flow out drains on each corner of the sunroof tracks.
The downspouts ( drains) may be clogged
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 19 Jan 2017, 06:46 pm
You say,"sun roof, I have a soft top convertibke. Do they theoretically use the same "gutter" track?
Old 20 Jan 2017, 09:56 am
Sorry, My mistake, Never had a Vert. You must have a seam pulling apart for the leak, probably nothing you can do on the cheap. Might be new top time.
73 Charger SE
01 Sebring flip
Old 21 Jan 2017, 08:40 pm
simplyrob's Avatar
I would not know where to start on that, other than to check the main front seal. I'm sorry I wish I could be more help.
Old 30 Jul 2017, 09:05 pm
Hi, I am having the EXACT issue as you. Have you found out anything to check? My car has now started to do same thing on drivers side sporadically. I am thinking it is the gutter that runs length of windshield and where the top sit's when closed, like a drawbridge , but it is not sealing properly. Maybe, stretched out?
I thought it had something to do with the lovely cut someone decided I needed in my top. But now that I read your post, I am beginning to think it just happened to start around same time. When I look at it, it does seem like it isn't sitting in the track quite right.
Good luck, and please share any info you have come across!!
Old 31 Jul 2017, 06:56 am
I don't know where you live, but you need to find a good body shop to take it to and have it checked there. Sounds to me like it's time for a new top and seals.
Old 31 Jul 2017, 07:40 am
Handy_Cruiser's Avatar
There are drain tubes running down both A-pillars. The number one cause of your problem is a blocked drain tube.
Old 31 Jul 2017, 09:05 am
I have been leaning towards the drain tunes being clogged. I am going to try and blow them out today.
Yes, I do need a new top, thanks to a HUGE JACKASS, that thought slashing 12 tires and my top a good idea! Thankfully, only 1 of his cuts went completely thru and it isn't even 1/4 inch spot. So, I have been putting it off in fear of the cost alone. I do body work and upholstery, on a much smaller scale. I work on motorcycles, so the car top is a little intimidating for me to tackle myself.
Old 31 Jul 2017, 09:09 am
rckstein's Avatar
If you need a new top, you might check with this member as he had a couple for sale:
NEW OEM Pt Cruiser Convertible Tops GENUINE MOPAR Tan & Black.
Tags
leak, pt conertible, water
Got another leak parkerjohn Tech & Performance Forum 3 15 Jul 2013 10:45 pm
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
Rear main seal oil leak 2005 turbo convertible. Deen General Turbo Discussions 7 09 Jun 2012 06:32 pm
2005 2005 Convertible top/drivers windows not working rabidaardvark PT Cruiser Convertible Forum 6 08 Sep 2010 10:48 pm
AC oil leak robinjoe General PT Cruiser Discussions 4 16 Sep 2005 03:38 pm
