auto window drop and fog lights
Like Tree2Likes
  • 1 Post By LionPT
  • 1 Post By ptcruisersteve
Old 16 Feb 2017, 01:00 am
Default auto window drop and fog lights
tried to program 2 new gray keys, in my 05 convertible. wouldnt take. bad battery. needed 12 volts or more.. replaced battery, now wondows wont drop and cant turn off fog lights. pulled fog light fuse. windows will still go up and down manually, but wont drop when doors are opened. ill try disconnecting battery with doors shut and windows up, if i dont screw up the rubber... fog light switch, was pushed in, and in off position, so they shouldnt have been on..
Old 16 Feb 2017, 02:03 am
Default Re: auto window drop and fog lights
What year is your PT Cruiser?
Old 16 Feb 2017, 04:24 am
_PTGT03's Avatar
not sure how it is on chryslers but on mercedes benz we have to hold down the button for an extra few seconds after letting go at the top point to calibrate for the new position. then the windows should go down. porsche calls this the 'claw-down' function
Old 16 Feb 2017, 05:11 am
rckstein's Avatar
Welcome to the forum
Old 16 Feb 2017, 06:57 am
LionPT's Avatar
Old 16 Feb 2017, 10:08 am
Originally Posted by LionPT View Post
Too much speed reading. Going to slow reading mode.
rckstein likes this.
Old 16 Feb 2017, 10:14 am
Post if the method in the link below does not work. This is the first step.
You should find out why the fog lights are staying on. Was this issue causing the battery to drain?
Smart Glass Modual Repaired.
Old 16 Feb 2017, 05:28 pm
To reset the doors need to be open on the convertible
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
Old 24 Feb 2017, 06:31 am
The fog light issue is probably the same one that almost all of us have had. The multi-function switch goes bad and they stay on all the time. A new aftermarket switch does not cost much and takes less than 10 minutes to change.
On my daughter's convertible, the Smart Glass would stop working after the battery was disconnected, but it would always start working again after a bit.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Dashboard lights out/window toggle lights out/auto door switch not working. mmelysee511 General PT Cruiser Discussions 9 26 Jan 2017 04:58 pm
Driver window auto close?? gbopper PT Cruiser Convertible Forum 9 27 Sep 2014 01:16 pm
window drop not working on my convertible jayln Tech & Performance Forum 4 07 Nov 2013 11:25 pm
Auto Power Window Problem nitrometal General PT Cruiser Discussions 5 26 Jul 2013 08:12 pm
Tear Drop Lights rix milligan Classifieds: For Sale/Trade 0 25 Mar 2003 05:47 pm
