Wheel bearing
Like Tree6Likes
Old 06 Apr 2017, 06:49 pm
Default Wheel bearing
I'm trying to track down a front end rattle/clunk. So far I've replaced the right control arm, strut mount (or motor mount), and one side of the sway bar bushings (so far). I plan to replace the end links with moogs as soon as I have time.
Now if it turns out its the bearings that need replacing is there a part I can buy that has the bearings already pressed and ready to go? Sorry to sound so stupid, but I've never dealt with this issue before. Thank you in advance.
Old 06 Apr 2017, 07:07 pm
LionPT's Avatar
Default Re: Wheel bearing
You want to buy a Wheel Hub.
Old 06 Apr 2017, 08:04 pm
Awesome. Thank you.
Old 06 Apr 2017, 09:51 pm
If there is nothing wrong with the hub you might want to just take it to a recommended shop that can press the bearings properly. You need a press to complete the wheel bearing assembly.
svtnos likes this.
Old 07 Apr 2017, 06:25 am
svtnos's Avatar
typically wheel bearings dont clunk.. they make more of a whurring , grinding sound when they start to go bad..
Busted_PT, Rayvin60 and JDK52 like this.
2003 PT Cruiser limited edition
Old 07 Apr 2017, 08:27 am
To my knowledge, there is no wheel hub available that has the bearing already pressed on. Dorman makes a replacement hub, without any bearing included. SKF makes one too; the bearing is included but not pressed on. Of course you can get a genuine Mopar one from the dealer too, but these do not come with prepressed bearings either.
This is because the bearing must be first pressed into the knuckle before the hub is pressed into it.
Old 07 Apr 2017, 02:40 pm
You also need to know what size wheel bearing your Cruiser has. I believe that they made 33mm and 39mm versions. Just not sure when they discontinued one size and switched to the other.
Old 07 Apr 2017, 04:11 pm
There are bearings in the upper strut mount that can cause a rattle and can be replaced separately from the strut.
Busted_PT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Apr 2017, 05:06 pm
Dont forget to make sure ground wire is reinstalled
Old 07 Apr 2017, 05:40 pm
When the wheel bearings start to go bad you might start to notice it with either noise or vibration at 55 to 60 mph. Gradually it might get worse where eventually the noise and vibration goes from 30 to 60 mph.
Wheel bearing ? PTloser32805 Wheels, Tires, Suspension 4 07 Jul 2016 09:10 pm
Wheel Bearing? TheAstronomer Wheels, Tires, Suspension 1 09 Apr 2015 08:25 pm
Wheel Bearing's anyone? TrannyManny Wheels, Tires, Suspension 13 30 Oct 2011 10:14 am
Wheel bearing!!?? jrs61282 Wheels, Tires, Suspension 0 11 Jun 2011 12:46 pm
which wheel bearing musicmanchuck4 Wheels, Tires, Suspension 0 08 Apr 2009 06:48 pm
