2005 PT Cruiser Convertible Question
  • 1 Post By 1spacemanspiff
Old 29 Jul 2017, 07:19 pm
Default 2005 PT Cruiser Convertible Question
Here is an image of our PT's PCM. It's missing the green connection (not sure what it is or it's needed). We took it into the dealer (they had it for a week) and $800 later they replace the plugs and wires. It still stalls and we have the following codes: P0508, P0032, and P0038. I believe these codes are for the IAC and O2 sensors (not sure if it one for both). It needs a smog but I want to figure out the missing connection and maybe replace the PCM first to hopeful fix the stall issue. Anyone have any other ideas? am I on the right path? and where the heck does the green connector do? We have an 2005 gt 5 spd
Old 29 Jul 2017, 07:54 pm
VsandFords's Avatar
Default Re: 2005 PT Cruiser Convertible Question
Welcome to the forum from Texas.
Old 29 Jul 2017, 08:15 pm
Thanks,
From NoCal
VsandFords likes this.
Old 29 Jul 2017, 08:25 pm
rckstein's Avatar
I believe that green PCM connection is for the auto transmission. I have found several pics where that connection is not used:
When you get a chance, please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread telling us a little about yourself and your PT.
You can go to this website:
Mopar Connection Repair Kit
You will get an error, but click on the HOME button in the upper right corner, enter your vehicle info, and you can look up all of the connectors, it will also tell you what pins control what circuits/components.
In the case of your Green connector:
POWERTRAIN CONTROL MODULE C4 (NGC) - BLACK/GREEN 38 WAY
Pin Information
Cav Circuit Gauge Color Function
1 T60 18 BR OD SOLENOID CONTROL
2 T59 18 PK UD SOLENOID CONTROL
2 T59 18 PK/BK UD SOLENOID CONTROL
3 -
4 -
5 -
6 T19 18 WT 2-4 SOLENOID CONTROL
7 -
8 -
9 -
10 T20 18 LB L/R SOLENOID CONTROL
11 -
12 Z14 16 BK/YL GROUND
13 -
14 Z13 16 BK/RD GROUND
15 T1 20 LG/BK TRS T1 SENSE
16 T3 20 VT TRS T3 SENSE
17 -
18 T15 20 LG TRANSMISSION CONTROL RELAY CONTROL
19 T16 16 RD TRANSMISSION CONTROL RELAY OUTPUT
20 -
21 -
22 T9 18 OR/BK OD PRESSURE SWITCH SENSE
23 -
24 -
25 -
26 -
27 T41 20 BK/WT TRS T41 SENSE
28 T16 16 RD TRANSMISSION CONTROL RELAY OUTPUT
29 T50 18 DG L/R PRESSURE SWITCH SENSE
30 T47 18 YL/BK 2-4 PRESSURE SWITCH SENSE
31 -
32 T14 20 LG/WT OUTPUT SPEED SENSOR SIGNAL
33 T52 20 RD/BK INPUT SPEED SENSOR SIGNAL
34 T13 20 DB/BK SPEED SENSOR GROUND
35 T54 20 VT/PK TRANSMISSION TEMPERATURE SENSOR SIGNAL
36 -
37 T42 20 VT/WT TRS T42 SENSE
38 -
My 2005 PT Cruiser GT Convertible Carnut PT Cruiser Convertible Forum 177 07 Jul 2018 04:37 pm
PT Cruiser Convertible 2005 tomsimons95 Welcome New PT Cruiser Members 3 25 Apr 2016 04:24 pm
2005 PT Cruiser Convertible HYDROGENFUSION Classifieds: For Sale/Trade 5 25 Jun 2007 10:11 pm
2005 Pt Cruiser (non convertible) kingkong General PT Cruiser Discussions 3 04 May 2004 09:06 pm
New 2005 PT Cruiser Convertible skylight PT Cruiser News and Rumors 21 03 Nov 2003 09:01 am
