2006 Convertable-Window /Regulator Assembly
  • 1 Post By paulwells77
Old 20 Sep 2017, 12:02 pm
Default 2006 Convertable-Window /Regulator Assembly
My driver side window started stopping 1 1/2 " short of closing all the way.
I tried all the reset Smart Glass Widow Module procedures and it worked for a very short time, and now will not reprogram at all so it's stays open 1 1/2".
It's been suggested I replace the Window/Regulator assembly, and come to find out you have to replace both sides because of a software/Convertible issue. Chrysler does not have the driver side, only passenger side and I can't locate one anywhere.
Anyone know of a supplier that might have both, and another question would be is the motor/regulator interchangeable so I could replace only motor/reg on
driver side?
Any other possible solutions?
Thank you, Paul
Old 20 Sep 2017, 11:22 pm
rckstein's Avatar
Default Re: 2006 Convertable-Window /Regulator Assembly
I found both available from sources on Ebay:
05067684AC Right:
Power Window Motor MOPAR 5067684AC fits 2006 Chrysler PT Cruiser | eBay
05067685AC Left:
Window Regulator Front Left MOPAR 5067685AG fits 06-08 Chrysler PT Cruiser | eBay
But also using a dealership website to search for the parts, it appears that the part numbers above have been superseded to ending with "AG" and I also found those available on Ebay.
To verify what part is correct for your PT, you could call any dealership and using the VIN for your PT, they should be able to give you the correct part numbers for your PT.
But there is also a TSB out for the 'vert windows when they don't automatically lower when the door is opened.
https://www.revbase.com/BBBMotor/TSb...dPdf?id=133354
It may or may not be related to what is going on with your PT. But if it was me, before replacing any door parts, I would probably take it to a dealership to see if the issue can be corrected by some programming. Good luck
Old 25 Sep 2017, 12:10 pm
Rckstein...
Thank you for your help. Much appreciated.
Paul
rckstein likes this.
Old 25 Sep 2017, 12:47 pm
driver side?
Thank you, Paul
Which procedures did you try?
Window Regulator Problems Kriegwulfe General PT Cruiser Discussions 1 12 Aug 2014 04:44 pm
2001 Power Window Regulator TaupeCruiser General PT Cruiser Discussions 0 01 Mar 2014 09:23 pm
2004 POWER WINDOW REGULATOR PARTS CRASHFIVE General PT Cruiser Discussions 3 03 Oct 2013 09:23 pm
WINDOW REGULATOR tanyanok Tech & Performance Forum 0 17 Aug 2011 11:37 am
window regulator and cables needed rsr02 Classifieds: Want To Buy 3 16 Dec 2010 08:01 pm
