RKE module
Like Tree2Likes
Old 10 Nov 2017, 09:13 pm
Default RKE module
The power door locks arent working on my 2005 Convertible. The horn chirps when locking, and the lights come on when unlocking, but locks nothing. Can here the module clicking.
I tried a RKE module from a 2001, but no difference. Disconnected battery for awhile too. I have a 2005 sedan and was wondering if that would work, or is it a special RKE module for the convertibles. Dont want to pull the other car apart to try it if its not the right one.
Old 11 Nov 2017, 08:18 am
ptprice's Avatar
Default Re: RKE module
If you haven't checked the 20 amp fuse # 3 (door locks) in your in dash fuse box give it a peek. It might just be the fuse not the remote keyless entry module.
Happy PTin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 11 Nov 2017, 01:16 pm
First thing I did. Fuse is good.
Besides, you can hear the module clicking? Horn chirps at locking, lights on at unlocking.
Everything works as it should, except the power locks dont work??
Old 11 Nov 2017, 01:25 pm
The information below is for a 2001 Pt Cruiser but might be helpful.
The fuse block feeds power to the RKEM from 3 fuses. The RKEM controls both alarm and door lock functions. The lock buttons on the door panel do not connect directly to the lock motors. Everything goes through the RKEM. The Remote Keyless Entry Module is located under the dash. You should verify that the correct voltage inputs are on the corresponding pins. The ground circuit should also be verified prior to replacing the RKEM.
Fuse 13, 10amps, delivers constant power to pin #9.
Fuse 3, 20 amps, delivers constant power to pin #3.
Fuse 10, 10amps, deliver switched ignition power to pin #22.
Pins 8 &12 are ground wire
I would suggest checking all three fuses first.
ptprice likes this.
Old 11 Nov 2017, 01:53 pm
ptprice's Avatar
Here's the location of the other fuses under the hood.
Do your doors unlock with the door switch?
Old 11 Nov 2017, 01:58 pm
No. The only way to lock and unlock the doors is with the key, or pushing down the plunger on the door.
ptprice likes this.
Old 11 Nov 2017, 05:46 pm
ptprice's Avatar
If your electric door lock switches don't activate the door locks that's probably pointing to a bad fuse. Possibly one of those other fuses ptcruisersteve suggested might be bad.
I actually had similar problems with bad fuses after a repair was done by a clown of a mechanic who lazily swapped some fuses in the PDC instead of using new ones. Open up the power distribution center and check the fuses. I've pictured it's location below.
Old 11 Nov 2017, 08:41 pm
Thanks. Ill look at that the next day its not raining.
Old 23 Nov 2017, 02:04 pm
Checked all the fuses, which all look good, and cleaned all the terminals, just to make sure. Swapped out the big green fuses with others I had from another car, just in case it looked good, but wasnt. Should I buy a new green or pink fuse just to make sure?
Replaced the RKE module with another one with the exact same number on it, still the same. Get the clicking, alarm set, and lights on, but no locks.
Am going to check the power to the pins, as you suggested.
Hopefully its a bad wire!
If not, any other suggestions?
Thanks.
Old 07 May 2019, 04:51 pm
Its been awhile as my PT Vert was parked for the winter. Still have the same problem. Have checked all the fuses, and wires on the plug for power and grounds, as suggested by others, and all are good. Tried the other module from my 2005 sedan, which I know works, and get the same clicking. Lights flash and horn chirps, but locks don't do anything. Module just clicks! Buttons on both doors do the same clicking noise. Does the battery need to be disconnected when switching modules?
Have run out of ideas, Anyone having any other suggestions would be greatly appreciated.
Air bag module newred5 Tech & Performance Forum 7 15 Jan 2014 08:34 pm
RKE Module oicurok2 Classifieds: Want To Buy 3 05 Jan 2014 07:21 pm
rke module replaced SIRVNCLT Tech & Performance Forum 0 28 Jan 2013 09:42 am
PCM/ECU Module Morkeste Tech & Performance Forum 43 04 Aug 2011 10:23 am
Fan Module mpw3ed Tech & Performance Forum 1 14 Mar 2011 06:29 pm
