Passenger windows not working after battery disconnect
Like Tree3Likes
  • 1 Post By brian2002utd
  • 1 Post By VsandFords
  • 1 Post By ptcruisersteve
Old 06 Jan 2018, 02:22 am
brian2002utd's Avatar
Default Passenger windows not working after battery disconnect
I know there is allready a thread on this but it is from several years ago. I have a 2005 convertible turbo and while doing some work I disconnected the battery. After reconnect both passenger windows won't go down. The drivers side and convetible top work fine. I have heard of the "ghost in the computer" rumours but does anybody know what exacty causes this issue and the correct fix for it?
Old 06 Jan 2018, 03:54 am
Default Re: Passenger windows not working after battery disconnect
Fixed! Just disconnected the battery for about 30 min. Weird!!
rckstein likes this.
Old 06 Jan 2018, 09:27 am
VsandFords's Avatar
Gremlins! When they don't have electricity to feed off of, they will leave.
Hope you evicted them for good!
Old 06 Jan 2018, 11:35 am
You most likely reset the smart glass module by disconnecting the battery for 30 minutes.
Old 06 Jan 2018, 11:42 am
rckstein's Avatar
One could think that he would have had a problem with all the windows. But at least he got it fixed.
Old 06 Jan 2018, 12:55 pm
If you have a convertible Pt Cruiser like I do you will see that you will pay more attention to details on anything related. The Smart Glass Module sometimes looses memory and the TSB link below indicates it can happen to either window or the convertible top.
http://ww2.justanswer.com/uploads/n9...125719_tsb.pdf
Sometimes trying to reset the Smart Glass Module with the battery disconnected for a specific time does not work and you might need to flash the Smart Glass Module but it is a cheaper way to fix it as long as the module holds the reset.
There are other TSB's regarding this issue with the convertible Pt Cruisers as more of the 2005 through the 2007 convertible Pt Cruisers started having this problem.
How do I disconnect this passenger airbag harness? KroozinNb00zin General PT Cruiser Discussions 2 30 Jul 2015 07:02 am
Help! Windows Not Working After New Battery Installed toplesscruiser General PT Cruiser Discussions 15 08 Feb 2014 05:17 am
after dead battery passenger side windows won't work valcansa General PT Cruiser Discussions 12 06 Jun 2013 10:49 am
Issues - Rear passenger blinker out, passenger window not working eobryant Tech & Performance Forum 0 23 Apr 2010 12:51 am
Negative battery terminal disconnect necessary? KingKole02 Sound and Security Forum 11 16 Feb 2004 03:12 pm
