Dome light LED replacements?
Like Tree9Likes
  • 1 Post By brian2002utd
  • 1 Post By rob302
  • 1 Post By Handy_Cruiser
  • 2 Post By rob302
  • 1 Post By CruiserMike
  • 1 Post By UnitD77
Old 25 Mar 2018, 09:08 pm
brian2002utd's Avatar
Default Dome light LED replacements?
Has anybody found an LED replacement for the 2 dome lights that are mounted under the sport bar? I have searched online and have not had any luck!
Handy_Cruiser likes this.
Old 26 Mar 2018, 08:06 am
Handy_Cruiser's Avatar
Default Re: Dome light LED replacements?
Yes.
Another member figured out that these LED fixtures will work in both the sport bar and in the trunk. He said that he had to take a Dremel and wide the holes just a little and then the fit was perfect.
I bought a set almost two years ago but haven't installed them yet. They are on my to-do list.
Here's a link to the fixtures:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 26 Mar 2018, 09:34 am
rob302's Avatar
neat idea.
one small change to that recommendation... if i may.. i recommend using a 3500k - 4000k light as a 6000k casting sharp shadows from above above will make you look ugly and old
Old 26 Mar 2018, 11:55 am
Originally Posted by rob302 View Post
neat idea.
Ugly and old? For me, that's just impossible!
Old 26 Mar 2018, 01:31 pm
rob302's Avatar
see here:
_____________6000k________________________________ 3500k______________
Old 26 Mar 2018, 03:31 pm
see here:
Attachment 28177Attachment 28178
That's just the difference in being studly on a sunny day and studly on a cloudy day. Either way, the studliness remains.
Joking aside I agree with snobby Robby, the warmer LED's would be better if you can find them. The ones I got myself and referenced here were the same ones as used by the previous member I mentioned that first figured this out. Not everyone can pull off the cloudy day stud puppy thing like me. So If anyone finds some 1.5" LED fixtures like these with a warmer color, they ought to post it so we all can look good in dome light.
rob302 likes this.
Old 31 Jul 2018, 10:09 pm
Update. The bulbs for the map lights fit perfectly into the dome lamps. The lamp is a slightly different size but the base connector is the same.
Old 07 Aug 2018, 10:27 am
Replaced all My interior lights and Licence plate with bulbs from this place. Looks great and make a BIG difference!
https://www.superbrightleds.com/
Old 07 Aug 2018, 06:36 pm
thank you for this site!!
i may be on there for a few hours!
For those that have replaced most interior lights or outside lighting with LED on your PT. Did you have to replace relays and such? i see that they recommend an LED flasher (which i'm guessing replaces the signal flasher behind the wheel?)
Old 07 Aug 2018, 09:09 pm
the only relay you would need is the flasher relay. I just walked into autozone and asked for a Variable Load Relay, and after some snooping around in sales books, the old guy behind the counts found me a part, plugged it in and it worked just fine. The only issue I have is that it isn't insulated like the stock one is so it makes a louder sound as it cycles.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Third Brake Light and Dome Light not working metalcruiser General PT Cruiser Discussions 5 27 Feb 2012 04:03 pm
interior led, map light and dome light pics outfit Interior Accessories Forum 29 23 Jul 2011 04:42 am
Dome light. WolfmanG Interior Accessories Forum 1 28 Nov 2010 06:22 pm
***HELP! My dome light went out*** PuToCruiser Tech & Performance Forum 2 24 Sep 2010 07:01 pm
DOME LIGHT turbomangt Exterior & Interior Styling 2 23 Dec 2004 02:57 pm
